Results 1 to 10 of 10
Thread: Water for Icemaker
    DIY Junior Member Robert May's Avatar
    Jan 2013
    Wayland, MI
    Question Water for Icemaker
    Should I supply hard water or soft water for the icemaker on my new refrigerator. Both are available with about the same difficulty.
    IBEW Electrician big2bird's Avatar
    Sep 2012
    Anaheim, Ca.
    I am quite sure you do not want to ingest soft water.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by big2bird View Post
    Why not? I use only RO filtered "soft" water for ingesting.
    The only reason for not ingesting soft water would be if you are on a low sodium diet. RO water is NOT the same as "soft water". Hard water will give you cloudy cubes because of the suspended minerals in it. Some sites will say not to us RO water, but my icemakers, and others I service, have used it for decades without any problem, and with clear cubes.
    Feb 2011
    NW Ontario, Canada
    Just how much sodium do you expect to get from ice cubes to make it a concern?
    True. It is softer. RO filtration can affect the pH and also being the "universal solvent" that it is, can be "aggressive" in dissolving some metals such as copper.
    Yes, I do get nice clear cubes from RO water.
    Sep 2012
    Anaheim, Ca.
    I use my RO to feed my icemaker also. When he said "soft water" I assumed he meant a salt water unit.
    Feb 2011
    NW Ontario, Canada
    Even so, the amount of sodium that would be added to the diet from ice cubes made with soft water is so minuscule as to be laughable.
    DIY Junior Member towens's Avatar
    Jan 2013
    central pa
    Longtime lurker, first time poster. Slight hijack, please.
    Whole house remodel, ran copper for an icemaker, figuring it would come off a RO filter under sink. Heard a few theories about compatibility of RO water and copper, wondering what the collective wisdom of this board is. Copper is buried in wall.
    TIA, Todd
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    Quote Originally Posted by towens View Post
    TIA, Todd
    You shouldn't use copper after the water has been treated by a RO unit.
    THere's a reason water is called the universal solvent. RO treated water is quite aggressive and is much more able to attack (dissolve) things verses more common water that contains minerals. Probably not a good idea to use it with a copper line.
  1. Water pressure for icemaker
    By brew24 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-29-2011, 12:19 PM
  2. water line to icemaker in fridge
    By brew24 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-06-2011, 05:17 PM
  3. Icemaker make-up water slow
    By Guest in forum Plumbing Forum Discussion & Blog
    Last Post: 06-12-2010, 05:14 PM
  4. Water Line for Icemaker
    By runner-guy in forum Plumbing Forum Discussion & Blog
    Last Post: 06-28-2007, 03:29 PM
  5. poor water taste from icemaker
    By dj in forum Plumbing Forum Discussion & Blog
    Last Post: 07-01-2005, 06:36 PM
