Results 1 to 3 of 3
Thread: steam boiler radiator return pipe
    DIY Junior Member rcdba's Avatar
    Jan 2013
    Brooklyn, NY
    Default steam boiler radiator return pipe
    I have a steam boiler radiator system. The return line of threaded black pipe in the basement is corroding. I've already spotted a leak. I replaced the part with a new piece and it was full of water. Because I would like to finish the basement, the return piping needs to be replaced. It's quite an investment. Currently, parts of the piping is laying on top of concrete and partially embedded in concrete. It only lasted for 25 years. The current pipe is 1-1/4 diameter.
    Is there another material I can use to replace the return pipe. Something better than black pipe. Stainless steel, Cooper ? If so, what grade?
    To last longer, I would like to bury (not embed) the pipe under the concrete slab with a waterproof wrapping and surrounded with a gravel bed to keep it dry. Is this possible ?
    Also, is it normal to have water in these pipes ? I had to close the water valve to the boiler and drain it? It does have a Hartford Loop.
    thanks for looking
    Richard
    Aug 2009
    South*East
    With a Hartford Loop that line will hold water. The reason for the loop is to protect the boiler from loosing all of it's water should a leak in the return line happen.
    John
    Jan 2013
    Brooklyn, NY
    that makes sense.. Thank you, John
  1. Boiler & steam valve pipe
    By djackson1090 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-22-2010, 11:30 AM
  2. Adding a Steam Radiator
    By Fein in forum Plumbing Forum Discussion & Blog
    Last Post: 12-13-2009, 08:46 PM
  3. Radiator with all pipe work from boiler.
    By Walter Schwartz in forum Plumbing Forum Discussion & Blog
    Last Post: 11-02-2007, 04:05 PM
  4. Pan for steam radiator?
    By Bruce in forum Plumbing Forum Discussion & Blog
    Last Post: 04-26-2005, 09:56 AM
  5. Looking for a used steam radiator
    By fgreen in forum Plumbing Forum Discussion & Blog
    Last Post: 09-15-2004, 01:13 PM
