Results 1 to 11 of 11
Thread: Reccomend electric Valves into 1-1/4" PVC pipe
    DIY Junior Member Dolphin's Avatar
    Dec 2012
    NV
    Default Reccomend electric Valves into 1-1/4" PVC pipe
    I want to install some 110V electric valves in my well house project. All the pipe is 1 1/4" PVC, inside well house, 10 deg to 130 deg range of temp in the well house.
    standard pressures, <80 psi
    I would like one normally open valve, one normally closed valve... so I can apply the same control power to reverse them.....
    Any suggestions would be appreciated.
    DIY Junior Member greenmonster304's Avatar
    Apr 2011
    Hampton Bays, NY
    I think 110v valves will be expensive. You could use 24v solenoid valves with relays and a trasformer.
    Dec 2012
    NV
    I assumed that was the case.... any good source for all these goodies? thx
    Apr 2011
    Hampton Bays, NY
    NO valve-http://www.irritrol.com/valves/100centuryplus.html
    NC valve-
    http://www.irritrol.com/valves/valves_200bs.html
    Relay-
    http://ribrelays.com/
    Any 24v transformer.
    If these valves are on the same line, a "3 way valve" will do the same thing.
    Dec 2012
    NV
    Thanks for the links and suggestions, much appreciated....
    I think I can make a 3 way valve work... agreed, it would simplify....
    doesn't appear Irritrol makes a 3way.... any other makers for this application in 3way?
    thx
    Irritrol is a "lawn sprinkler" company and as such ONLY makes simple valves which are all that are needed for 99.999999+% of installations. Do an Internet search for electric 3 way valves then sort out which of the "hundreds" of replies you want to investigate.
    Dec 2012
    NV
    I had already done that... Asco 3way valve was the best I could find, at about $1k price range...
    two of these make more economic sense...
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    You could get a Jandy 1-1/2" 3-way valve made out of CPVC and an 24v electric actuator for $200.
    No NSF or anything but it will handle the pressure and flow.
    http://www.zodiacpoolsystems.com/~/m...oads/SL/SL5250
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    Dec 2012
    NV
    Thank you for the Jandy recommendation.... these seem ideal, even their check valves...
    your NSF comment made me curious....
    for a small well house, that serves only a max. of 4 residences, do control valves require NSF? I would think not?
    thanks..
    DIY Junior Member expressre's Avatar
    May 2013
    1-1/4'' is a weird size but if your still looking you can find some here http://www.electricsolenoidvalves.com/1-1-4-valves/
  1. Ball valves in pvc pipe
    By Treeman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2010, 04:00 AM
  2. Electric Pipe Wrap
    By Repairman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2009, 07:06 AM
  3. Hot water heaters-- reccomend # of elementsand wattage, install costs
    By trav in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2007, 07:52 PM
  4. pipe threads for angle valves
    By nirugpatel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2005, 07:38 PM
  5. Extra valves after re-pipe
    By Jakemembers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2004, 03:16 PM
