Results 1 to 9 of 9
Thread: Acrylic shower Base ( cold 36x60
Hybrid View
    DIY Member royerm's Avatar
    Jul 2010
    Quebec, Canada
    Default Acrylic shower Base ( cold 36x60
    Hi Folks...
    As I'm preparing for a new shower install in the basement I decided
    to bring the acrylic base from the garage to see approximately where
    the drain would end-up etc etc etc....
    It was standing up right in the cardboard in the garage and
    when I put it on the floor I noticed it was curved a bit on both axes,
    the middle being the most protruded on the 4 sides.
    I'm keeping it inside for the night to see if it will straighten-up..
    Any comments???? is this normal???
    Regards
    Well............it's made in a mold and then pulled off. Nothing is perfect in construction. That's why they make shims.
    Sometimes it's good enough, and sometimes not.
    Most tubs, if you are looking at the line that meets the floor, those bow a bit too.
    Jul 2010
    Quebec, Canada
    Thx Terry....Do you think that temperature can have an effect on it????
    I would need a picture. I know that black ABS pipe left in the sun will curve when one side is warmer than the other.
    Jul 2010
    Quebec, Canada
    Terry and all...
    I ended-up leaving the base sit in one of the bedroom that has floating floor that is
    pretty much levelled and with a bag(40lbs) of wood pellet in each corner for a day.
    After removing the bags and leaving it alone for a day, the sag is very small now
    and with the weight of the shower door sitting on it I'll be fine...
    Cheers
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by royerm View Post
    Terry and all...
    Cheers
    Or you can scratch the back side of the shower pan with a razor blade a million times. Use a slurry coat of something sticky like Laticrete 254, Ardex X77, Mapei Grani Rapid, Custom Mega Lite and then drop it on a mortar mix base that went down over the same slurry coat. Tap it into perfect placement. Weight it and know for sure it is rock solid.
    Any pre-made base we see installed with out this added work just feels weak under foot.
    JW
  1. Best caulking for acrylic shower base
    By dirtmover in forum Shower & bathtub Forum & Blog
    Last Post: 11-08-2010, 05:11 AM
  2. Looking for good quality fiberglass/acrylic shower base and sliding doors
    By bases in forum Shower & bathtub Forum & Blog
    Last Post: 11-02-2010, 12:48 AM
  3. Where to find 48"x48" double threshold acrylic shower base??
    By wrenchguy in forum Shower & bathtub Forum & Blog
    Last Post: 05-24-2010, 07:30 PM
  4. Acrylic Tub - Wooden Base
    By mehlhorn in forum Shower & bathtub Forum & Blog
    Last Post: 03-08-2010, 11:02 AM
  5. Drain installation in acrylic shower base
    By rjm in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2007, 12:41 PM
