Results 1 to 10 of 10
Thread: Didn't know about pipe dope, now what?
    DIY Junior Member rafigso's Avatar
    Sep 2012
    Greensboro, NC
    Default Didn't know about pipe dope, now what?
    I have 2 shower valves and one of them has a one drop at a time leak from the threads. I used Teflon and no dope. I would have used the dope if I had known about it. Short of cutting out the valve and reconnecting everything, is there a sealant I can put around the outside of the threads to seal this drop by drop leak?
    Thanks in advance,
    Rafael
    No. There is nothing that will seal from the outside.
    You will have to cut and redo the joint. It may be that it just wasn't tight enough.
    Options are:
    Tape
    Dope
    Tape and dope
    I would normally just use dope. I don't really like getting too much heat near a joint with tape.
    Jan 2008
    No, removing it and redoing the leaking fitting is the correct method of repair. I prefer solder/sweating valves in place for this reason.
    Yakima WA
    I think the best way to do this is to sweat the male adapter to the copper pipe before screwing the adapter into the shower valve. Additional soldering can be done to complete the installation without getting the valve too hot.
    Sep 2012
    Greensboro, NC
    Thank for the quick reply, took everything out and used the dope, everything is good now.
    I never use tape on metal threads, only for PVC.
    Nov 2010
    Maine
    I have never used tape in my life for anything except wrapping presents
    Mar 2011
    Houston, TX
    Pipe dope is illegal in Texas.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    But not in Washington or Colorado!
    Doesn't help me any though. I like micro beers. I don't put anything in my body that won't wash out in 24 hours.
    THC has a half life of 28 days.
    Mar 2011
    Houston, TX
    There is nothing better than a Beer after a hard days work.
    Well, maybe a cigarette after you lay a bunch of pipe, that may come close.
  1. Sweating near pipe dope
    By Viking in forum Plumbing Forum Discussion & Blog
    Last Post: 03-14-2011, 05:49 AM
  2. Which pipe dope?
    By rsmith99 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-22-2008, 05:33 AM
  3. thread sealing... pipe or dope?
    By Hube in forum Plumbing Forum Discussion & Blog
    Last Post: 05-08-2007, 12:45 PM
  4. Pipe Dope vs. Teflon Tape
    By chefwong in forum Plumbing Forum Discussion & Blog
    Last Post: 09-01-2006, 07:58 PM
  5. Pipe Dope vs. Teflon Tape
    By jamckelvey in forum Plumbing Forum Discussion & Blog
    Last Post: 05-22-2006, 12:34 PM
