Results 1 to 8 of 8
Thread: Losing water pressure = leak?
    DIY Junior Member jptemp's Avatar
    Jan 2013
    CT
    Default Losing water pressure = leak?
    I am stumped. I have an apartment where the bath and kitchen fixture and water heater are all fed by one 1/2" line with a ball valve. Shut off the ball valve and no water goes to any fixture.
    I shut the valve off, and the next day I turn on a faucet and there is almost no pressure. Shouldn't the lines stay pressurized over night? There are no water leaks that I can see. None of the fixtures drip. the pressure relief valve on the water heater does not drip.
    It seems impossible.
    Jan 2008
    I would not expect to find much in the way of residual pressure. A few drips in the toilet tank and you would never notice. If you want to get serious about your "testing" you could put a pressure gauge in the line and see what happens.
    Anyone flush the toilet? Since the pipes don't really stretch at the pressures in a normal home, that leaves maybe the rubber/plastic hoses to the faucets that can act like a bladder to help hold the pressure. All it takes is a VERY small amount of water coming out somewhere to relieve the pressure. That could happen just by the water cooling off, especially if you turned the WH off, since the cooler water is more dense (i.e., takes up less space). Do you have an ice maker on the frig?
    Jan 2013
    CT
    No, the toilet was out do redo the floor.
    About half of it is type A pex and half copper. Would that do it?
    Water heater was on and no ice maker.
    Jan 2013
    CT
    The toilet was out at the time. I could put a pressure gauge on the kitchen sink, all I would need is an adapter to a male garden hose thread. I suspect the pressure will drop from 50 to around 10.
    Why are you worried about it? Unless the pipes are not all visible, you obviously do not have a leak. The pressure could drop for any number of reasons, but unless it were ZERO, a leak could not be one of them.
    Jan 2013
    CT
    I'm worried about it because the pipes are not all visible and it might be leaking somewhere inside the walls, creating mold, wood rot, etc.
    Just the simple act of the house dropping in temp might would make the pressure change. Colder water shrinks until it gets to about 34-degrees, then starts to expand again (the reason ice floats).
  1. Xtrol Water Pressure Tank Slowly losing pressure throughout the day
    By Shaun091382 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-01-2012, 05:03 AM
  2. Losing Hot Water Pressure (only)
    By lukus in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2008, 12:48 PM
  3. losing water pressure
    By boogsdaddyrick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-20-2008, 09:29 AM
  4. Losing water pressure
    By pisgahmountain in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-16-2008, 12:17 AM
  5. Losing Water Pressure
    By klecas in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-28-2007, 10:52 PM
