Results 1 to 5 of 5
Thread: "found a kinetico"
    DIY Junior Member cdg1981's Avatar
    Jan 2013
    texas
    Default "found a kinetico"
    Hello ALL!!
    Today I was helping a friend clean out an old barn and we came across a kinetico water softener its a 3 tank system with a salt tank. I was wondering if this would still be usuable? the tanks are pretty heavy 100 plus lbs. I didn't inspect it much but i do know its a kinetico, where might i find a model type or number on the unit? I have looked through some of the forums and looked at a few pics tonight and haven't came across a unit that looks the same yet. This unit has been sitting in storage for at least 7 yrs plus and when we moved them I think i heard some water slush around in them. I'm mostly curious to if this system would still be okay to use since it has been stored (possibly with water left in them) might try to take them off his hands!!
    Nov 2005
    Central Florida
    You could ask a local Kinetico dealer about it; they might give you a free evaluation of the unit.
    DIY Junior Member Servallwater's Avatar
    Jan 2013
    Las Vegas, NV
    Hello
    If you had a picture of the system I would be able to tell you what type of system you have. Kineticos are good systems but can be pricey to repair. If that unit has been sitting in storage for 7 yrs the resin will probably need to be replaced and probably need work inside the head. There are lots of moving parts and seals inside the valve of a kinetico. If you are mechanically inclined you should be okay rebuilding the valve. Depending on the type of Kinetico system you have the price in Las Vegas ranges from $2500-$3500 for a Kinetico water softener. Rebuilding with resin, level seals, drain pistons, and some other misc parts will prob cost you $600-$800.
    Jim Owens
    Servall Water Conditioning
    3065 N. Rancho Dr. Suite 142
    Las Vegas, NV 89130
    www.serveallwater.com
    702-737-1957
    "If we cant fix your problem, you don't pay anything!"
    Servall Water Conditioning has been servicing the Las Vegas valley since 1978.
    Jan 2013
    texas
Size:  73.2 KBName:  photo (2).jpg
Size:  55.7 KBName:  photo (3).jpg
Size:  69.7 KBName:  photo.jpg
    here are a few pics if they show up..............
    if anyone wants some top notch plumbing done give pm me LOL
    Also what type of filters would be required for well water, any specific types for this kind of system???
    Jan 2013
    texas
    sorry for the same pic over and over,the other tank there is supposedly an Iron filter/tank i wasn't planning on using it. my current water is just hard, no smell, and tastes like country well water should
    I rigged it up so that it would run through a few cycles to get any old water out. Works fine I think, thinking about installing it next weekend is there anything I need to look at closer as far as proper operation?
    a few more ?'s
    What does the number on the disk mean? this one has a 2 on it?
    As far as the two 3/8ths in line go, Is there a certain place they go? i know one discharges and the other adds water to the brine tank, but how does the water from the brine tank get back into the resin tanks?
  1. HELP....Starting from Scratch ... found 6" Well in yard
    By NT in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-12-2011, 09:40 AM
  2. Frozen Kinetico, options/questions on "proper" install
    By dyeager535 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-25-2011, 10:36 AM
  3. "Machine Gun" or "Thud" and a Weeping Toilet...oh my!
    By maxxis in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2009, 07:38 PM
  4. Difference between "thinset" and "dryset" mortar...?
    By Fistor in forum Remodel Forum & Blog
    Last Post: 07-31-2008, 02:44 PM
  5. Just found out about the low flow "mandate"
    By galevin in forum Toilet Forum discussions
    Last Post: 05-04-2006, 08:49 PM
