Results 1 to 2 of 2
Thread: Bath Overflow drain Gasket issue
    Structural Engineer jestructure's Avatar
    Jan 2013
    New york
    Default Bath Overflow drain Gasket issue
    I'm installing a new Americast 5'-0" tub with a Watts brass tub drain assembly.
    everything was moving smoothly until I went to install the tapered washer on the backside of the tub overflow.
    I understand that most of the time the thick side of the washer goes down. In this case, I cannot get a tight seal between the tub and the overflow flange with the supplied tapered washer. IF the bottom is tight, there is a gap at the top. It appears that the angle of the tub and the angle of the overflow flange is nearly identical. I cannot find a thick flat washer locally for this application.
    Any suggestions would be greatly appreciated.
    Turn the tapered washer sidewise. I install them that way all the time in that situation. All you're looking for is a tight seal all the way around. There are tubs that need the taper at the bottom, but certainly not all of them.
  1. Bath tub waste & overflow drain installation.
    By motonutz123 in forum Shower & bathtub Forum & Blog
    Last Post: 11-13-2010, 07:30 AM
  2. Tub Overflow Drain Issue
    By dgibson32 in forum Shower & bathtub Forum & Blog
    Last Post: 01-23-2010, 07:02 AM
  3. Leak from overflow gasket on tub drain
    By yaozer in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2009, 06:15 AM
  4. drain and overflow rubber gasket problems..
    By chris fox in forum Shower & bathtub Forum & Blog
    Last Post: 03-22-2008, 08:38 PM
  5. Installing an overflow drain in a new bath tub in a manufactured home
    By dmachamer in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2006, 04:28 PM
