Results 1 to 1 of 1
Thread: Proper Way To Level Sterling Accord Shower In Mobile Home
    DIY Junior Member gtpvette's Avatar
    Mar 2007
    Florida
    Default Proper Way To Level Sterling Accord Shower In Mobile Home
    Hey Guys. I'm redoing the bath in my weekend mobile home and hit a snag. I dry fit a 60” 4 piece Sterling Accord shower this weekend and the back wall is about 1 1/2" out from the studs at the top. It looks like the floor has a major drop from back to front. So the question is what is the best way to level this thing?
    I've read about the mortar/thinset/sandmix in piles and it would certainly do it but I'm a bit concerned about the front lower edge of the shower not being directly supported. The plan is to install a set of bypass doors and I would think they would need to be properly supported by that front edge. DO you think this is a real problem??
    The second thought I had was to build a small platform to set the shower stall on. Just rip some strips/wedges with the proper angle front to back maybe 2” high then cover with ” plywood. Then set the shower on that. The only additional work would be tiling the front edge .
    Of course the real problem is the mobile home itself. Nothing is square,,, probably never was. No rot or sag in the bathroom that I can see, it’s just everything is just off a bit.
    So what’s your favorite way to raise the outside edge of a Vikrell Shower pan??
    Many Thanks!
    Fred
    Before demo
    Almost ready,,,, drywall still needs to come off. How do you like that wall paper???
  1. Sterling Accord Shower questions
    By Mr Russ in forum Shower & bathtub Forum & Blog
    Last Post: 09-01-2012, 10:11 AM
  2. mobile home shower leak behind wall
    By bonnielw22 in forum Shower & bathtub Forum & Blog
    Last Post: 06-03-2011, 06:14 PM
  3. Comments - STERLING PLUMBING (KOHLER) ACCORD SEATED SHOWER STALL
    By chuck b in forum Shower & bathtub Forum & Blog
    Last Post: 01-29-2011, 07:40 AM
  4. Replies: 0
    Last Post: 01-03-2011, 10:26 AM
  5. New shower in Mobile home
    By Pewterpower in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2006, 07:09 PM
