Results 1 to 6 of 6
Thread: What type of DWV PIPE used in Canada
    DIY Junior Member poky1234's Avatar
    Dec 2012
    Woodbridge Ontario
    Default What type of DWV PIPE used in Canada
    Hi ,
    I am going to do a small washroom reno and was wondering what type of 3 inch DWV pipe should be used in the DWV system above the basement concrete floor, ABS OR PVC . I have 4 inch PVC under the concrete. Located in Ontario, Canada.
    Thanks,
    we generally use ABS for anythign above ground in a residential building
    DIY Junior Member JTlikestobuild's Avatar
    Feb 2013
    Vancouver BC
    Here in BC, ABS has been the standard for a long time but Sytem 15 PVC has made big gains. The PCS is quieter than ABS.
    Dec 2012
    Woodbridge Ontario
    Thanks for the replies guys!
    DIY Junior Member MikeON's Avatar
    Apr 2013
    gueph, Ontario
    QUOTE=mikeplummer;366388]we generally use ABS for anythign above ground in a residential building[/QUOTE]
    In Ontario, can we use ABS underground ? for example, building drain (horizontal sections underground) can be ABS or have to be PVC (white or green in color) ?
    Quote Originally Posted by MikeON View Post
    In Ontario, can we use ABS underground ? for example, building drain (horizontal sections underground) can be ABS or have to be PVC (white or green in color) ?[/QUOTE]
    my original post said for anything ABOVE ground - but to answer your question - yes ABS can be used for underground, but PVC sewer pipe is mainly used underground, especially for the building drain
  1. pipe size /max length of run for kitchen, Canada Code
    By Philbert in forum Canadian Plumbing Code Questions
    Last Post: 07-25-2012, 05:04 PM
  2. Have you seen this type of pipe before!?
    By Doherty Plumbing in forum Plumbing Forum Discussion & Blog
    Last Post: 10-27-2011, 09:12 AM
  3. Laundry drain pipe help for s-trap location. Canada
    By klrman in forum Canadian Plumbing Code Questions
    Last Post: 06-03-2010, 02:40 PM
  4. Laundry drain pipe help for s-trap location, Canada
    By klrman in forum Plumbing Forum Discussion & Blog
  5. What is the difference between type L and type M copper pipe
    By Dom Z in forum Plumbing Forum Discussion & Blog
    Last Post: 08-09-2009, 09:39 AM
