Results 1 to 4 of 4
Thread: Need help with Fog horn sound when water is running!
    DIY Junior Member maximus20895's Avatar
    Jan 2013
    Knoxville,TN
    Default Need help with Fog horn sound when water is running!
    Hello everyone!
    I would really appreciate your help!
    For about a year now, I hear a fog horn sound when the water is running. Most of the time it is either when a toilet is being flushed and sometimes it is when the washing machine when it fills up with water. The sound is constant and the only way to "turn it off" is to turn on a faucet and it goes away. If I turn the faucet back off the sound will continue until the toilet is done filling up and then it goes away until the next time I flush the toilet.
    I have heard of "water hammer", but I have read that it only happens when the water is off and it is due to turning the water off and then the pipes not having an air bubble to absorb the pressure. This, is kinda opposite in that it only makes a sound when the water is running and the sound is constant.
    I have tried and tried to find the source of the sound and I have no idea where it is coming from and to be honest with you I don't even know if it is only happening in one location. I also have tried to make it stop by turning the hot water on, but I don't know if that does anything or not as when I turn the faucet on the noise stops do I don't have a chance to test that out.
    One more thing I just remembered is that before the noise, when I would flush the toilet and take a shower the shower temp would not change at all, but for some reason now when I flush the toilet it seems that the temperature in the shower is hot and then changes to a little bit colder when the toilet fills up again. I don't know if this has anything to do with the problem just something I have noticed.
    And I just remembered two more things; One, I have changed the internals on two toilets such as the ball cock and flusher as well as completely replaced an entire toilet. Again, I don't know if that has anything to do with the problem, but I just wanted to let you guys know.
    The very last thing is when I turn on the hose outside sometimes the water spurts out like there is air in the pipes. I have also heard it make a noise from the hose too, but not that much.
    I think that is all the information I have for you guys.
    I really hope you can help me out here!
    Thanks a bunch!
    There are a few tips at this link
    http://www.terrylove.com/wwwboard/messages/2103.html
    And I would make sure that the shutoff at the wall is open all the way for the toilet.
    Feb 2011
    NW Ontario, Canada
    I'm guessing it is a pressure regulator that resonates at a particular flow rate. Rebuild or replace it and the noise should cease.
    It is probably a Fluidmaster fill valve, but it also happens with other brands, and it needs to be replaced. OR, you did not shut off the water valve to the hose, which can also cause the sound.
  1. sound from running water pipe
    By newbie1234 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2010, 04:59 PM
  2. Another wining to fog horn sound
    By NealWalters in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2009, 06:48 AM
  3. fog horn sound melting my sanity-HELP!!
    By scott41 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-31-2008, 03:33 PM
  4. Running water creating sound?
    By NLAlston in forum Shower & bathtub Forum & Blog
    Last Post: 03-31-2006, 03:18 PM
  5. Sound of Water Running when it's not
    By cballew in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-25-2005, 07:06 PM
