Results 1 to 13 of 13
Thread: Should I repair or replace water heaters?
    DIY Junior Member MEYLIN's Avatar
    Jun 2012
    Colorado
    Default Should I repair or replace water heaters?
    I have two State water heaters that are 14 years old. Water temperature is now warm rather than hot. I replaced expansion tank a year ago. Should we repair or replace water heaters?
    Gas or electric? Usually, I only recommend replacing when they start to leak. Your FIRST task is to find out why the water is only warm, otherwise, you may replace the heaters and find out you STILL have the same problem if it is functional problem.
    Jun 2012
    Colorado
    The water heaters are gas.
    Feb 2011
    NW Ontario, Canada
    My last State gas water heater lasted for 10 years before springing a leak. I would have liked to cut it open to see the innards as I suspect it had quite a build-up inside. The installer that took it out said it weighed a lot more than when it was new.
    I would not repair a 14 year old gas heater, figuring that the build-up inside would significantly reduce efficiency and capacity.
    Jun 2012
    Colorado
    Any recommendations for a replacement?
    In the USA, (nearly) all residential WH are now required to have protection from igniting vapors from volatile liquids that may be in the area. These have been problematic for some companies. They also generally mean that a new WH of the same volume will likely be taller, since the burner design is different to prevent that ignition. I'd look at Rheem or Bradford White. Some of their models qualify for Energy Star efficiencies, and may get you a rebate from your local utility company - well worth asking.
    I like the Rheem and Bradford White water heaters for replacement.
    14 years is pretty old for a gas water heater. So old, that they may not deserve a service call.
    Warm not hot?
    Have you checked the thermostat settings?
    Also, if you have been having plastic particles clogging faucet aerators, you could have bad dip tubes.
    Aos I said before, find out WHY you do not have adequate hot water, since it is NOT a common problem with gas heaters.
    Yakima WA
    About the only think worth repairing on heaters this old would be the dip tubes. There was a big bunch of defective tubes made by one manufacturer that supplied several brands of heaters several years ago. Your heaters may be from that time period. At any rate, dip tubes are easy to check and easy to replace if they are broken. Just remove the nipple on the intake side of the heater and pull the tube out. They should go nearly to the bottom of the tank. They are just a flanged plastic tube that hang in the hole under the nipple. Turn the water supply off first. LOL
    Dip tubes caused a lack of hot water volume, not a lack of temperature.
    Yakima WA
    Good catch, HJ.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    How are the wtr/htrs plumbed ?
    It is possible that one of them is not firing while the other one is heating the water but it mix's coming out of heaters giving you warm water !
    Then trouble shoot the one not working and repair as needed
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Jun 2012
    Colorado
    The problem was solved with a new thermocouple. Enjoying hot showers again! Appreciate everyone's comments.
  1. Replies: 596
    Last Post: 04-23-2013, 09:30 PM
  2. Electric hot water heater not working - repair or replace? Help!
    By aGrandma in forum Water Heater Forum, Tanks
    Last Post: 12-09-2010, 08:27 PM
  3. Replace or Repair Tank Water Heater
    By odyinpdx in forum Water Heater Forum, Tanks
    Last Post: 09-30-2009, 12:03 PM
  4. Repair, replace, or????
    By david3394 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-10-2009, 01:32 PM
  5. ice water box valve repair or replace
    By montreaux in forum Plumbing Forum Discussion & Blog
    Last Post: 11-17-2008, 08:02 AM
