Results 1 to 5 of 5
Thread: Hot water expansion tank
    DIY Junior Member jm66208's Avatar
    Aug 2011
    KC
    Default Hot water expansion tank
    I need to install a hot water expansionn tank Sunday, and the only place can get on e is the Home depot or Lowes. Is there a difference in quality as compared to one I could get Monday morning from the plumbing supply shop?
    Can't say. But, make sure you get one proper for your application - they come in hydronic heating versions (non-potable), and potable versions. THen, you have to determine what size you need which depends on the volume, temperature swings, and pressure of your supply.
    Yakima WA
    I got mine (Watts) at HD several years ago. My hometown Lowes did not even know what they were and still do not stock them. They do sell PRVs, which I find interesting. Watts is a good brand.
    Not really, but a potable water one will be galvanized and probably glass lined. A hydronic one will be black steel, which will rust out quickly in a fresh water system. Size, and initial pressure, are not as important as some make it out to be.
    Size becomes more important in the wintertime when you exhaust the WH's volume. All that cold water will need more room to expand than a more normal usage, where only a small amount of cold water then needs to expand as it is heated. The tank's bladder gets stressed more if it gets stretched further than designed (to accommodate that extra volume of expanding water), thus, the pressure and volume should match your needs.
  1. 2 Gallon Expansion Tanks...Hot water VS Well expansion tank
    By Its.me.again in forum Water Heater Forum, Tanks
    Last Post: 10-14-2012, 01:42 PM
  2. Replies: 15
    Last Post: 06-06-2011, 04:55 AM
  3. Hot water tank expansion tank vs T&P valve.
    By Mikebarone in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2008, 09:39 AM
  4. Well and Hot Water Expansion Tank
    By Mr_Magoo in forum Plumbing Forum Discussion & Blog
    Last Post: 08-21-2008, 05:10 AM
  5. Hot water expansion tank
    Last Post: 02-07-2008, 07:06 AM
