Results 1 to 4 of 4
Thread: How to drain 1 zone on radiator
    DIY Junior Member Daveclink's Avatar
    Feb 2012
    Syracuse, NY
    Default How to drain 1 zone on radiator
    I need to drain 1 zone out of 4 to work on a radiator
    each zone has a supply and return shut off with only 1 drain for the whole system
    Can I drain the 1 zone without draining the whole system?
    Thank you
    Dave
    Jan 2009
    Sure, but if it doesn't have it's own drain "inside" the section between the isolation valves you'll have to crack it open at a fitting to do that, and it may not be in the most convenient spot from a water-disposal point of view. Figuring out how to fill it without introducing a slug of air into the system may take some forethought too.
    Feb 2012
    Syracuse, NY
    Thanks for the input. It sounds like it will be easier to drain the entire system and fill the 3 zones leaving the 1 zone drained so I can work on the radiator.
    Is the following the correct procedure:
    turn up the heat in all zones for about 10 min
    1. turn the boiler off
    2. close the water supply line to the boiler
    3. attach hose to drain and drain the system
    4. close the valve to the zone I want to work on.
    5. open the water supply line to the boiler.
    6. turn on the boiler
    I'm sure I'm missing something
    Thanks again
    Dave
    Jan 2009
    In general it's easier to just drain the one zone if you can figure out where to crack it open. Draining the whole system introduces air and corrosive oxygenated water into the system- treat the "dead" boiler system water as if it were precious!
  1. Convert from zone valve to zone pumps
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 01-02-2013, 04:59 PM
  2. 2 zone system-no heat upstairs-Boiler doesn't fire when that zone asks for heat
    By MrBostn in forum Plumbing Forum Discussion & Blog
    Last Post: 10-13-2012, 08:33 AM
  3. Boiler not firing up for 2nd zone, only 1st zone
    By bjferri in forum HVAC Heating & Cooling
    Last Post: 11-04-2009, 03:50 PM
  4. Well guy...made my 4 zone sprinkler sys, now a 2 zone???
    By iPhoneSRQ in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-21-2009, 07:58 AM
  5. Dual zone vs. Single zone?
    By zombieman in forum HVAC Heating & Cooling
    Last Post: 03-04-2009, 04:48 PM
