Thread: Backwater valve sleeve
    DIY Junior Member meanrn92's Avatar
    Jan 2013
    missouri
    Default Backwater valve sleeve
    Hello all first post so here goes. We have a 4 year old house with a roughed in bath in the basement we are ready to finish. In the middle of the floor is a backwater extension sleeve this sticks up about 12 inches. The ID is 5 inches looking in the sleeve there is what looks like a clean out that would unscrew. What is this for do I need it? If I cut this sleeve flush with the floor what can i cover the hole with? Is there a need to access this valve? Can I fill the hole with concrete and forget about it?
    paul
    Nov 2010
    Maine
    You can cut it flush. You do need it. You can cover it with a flush cap
    Do not "fill the hole with concrete". Someday, you WILL need to remove that cover on the BWV.
  1. Backwater Valve
    By dlarrivee in forum Plumbing Forum Discussion & Blog
    Last Post: 06-25-2011, 11:52 AM
  2. backwater valve
    By maddon in forum Plumbing Forum Discussion & Blog
    Last Post: 01-02-2011, 09:20 AM
  3. Backwater Valve
    By chas22 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-03-2009, 06:32 PM
  4. double check valve same as backwater valve ?
    By Pan in forum Plumbing Forum Discussion & Blog
    Last Post: 02-26-2008, 07:14 PM
  5. What kind of backwater valve to use ?
    Last Post: 02-22-2008, 07:21 PM
