Thread: pipe squeal
    DIY Junior Member blove1344's Avatar
    Sep 2012
    New Cumberland,PA
    Default pipe squeal
    Just completed my bathroom remodel. The shower squeals for a few minutes after turning on the water then the squeal goes away. The noise
    sometimes starts right away but usually after it has been on a few minutes. It doesn't last long but can be loud and annoying. I removed
    the shower head and flushed the water line. Thought it might be debris. Could not get the head apart to clean it so I reinstalled it. I checked
    the water pressure and it reads 50 psi.
    Any suggestions?
    It may be in the shower valve itself, but if not, it could be turbulence in the head. The only way to determine which is to use a different head to see if it goes away.
    Sep 2012
    New Cumberland,PA
    Thanks, I'll try replacing the shower head first. Will let you know how it goes.
    Sep 2012
    New Cumberland,PA
    I installed another new shower head. This one has adjustable flow. It squeals as bad or worse than
    the original, in any flow pattern. The control valve is new as well as the copper pipe from the valve
    to the shower head and spout. I installed cpvc from the valve to both supply lines,which are also cpvc.
    What do I do next?
  1. shower squeal
    By rickford66 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-23-2010, 12:38 PM
  2. replacing drain pipe with RIDGID Model 246 Soil Pipe Cutter
    By texasitty in forum Plumbing Forum Discussion & Blog
    Last Post: 08-14-2008, 06:25 AM
  3. newer toilet and squeal/whine sound
    By SSzretter in forum Toilet Forum discussions
    Last Post: 05-01-2006, 01:53 PM
  4. new shower head squeal
    By sdpuzzles in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2005, 07:12 AM
  5. Pipe squeal
    By Bill in forum Plumbing Forum Discussion & Blog
    Last Post: 09-06-2004, 02:31 PM
