Results 1 to 5 of 5
Thread: Northstar - no soft water, replaced seals and rotor, about ready to give up
    DIY Junior Member earlrabbit's Avatar
    Jan 2013
    Salt Lake City
    Default Northstar - no soft water, replaced seals and rotor, about ready to give up
    My 13 year old Northstar water softener just isn't generating any soft water. I've cleaned the venturi and replaced the gasket in it. I've also replaced the seals and rotor in the valve. The system is cycling so I know the electronics are good. Any ideas?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Do you get a brine draw? Did you replace the figure 8 o ring? Does the water flow to the drain slow down once it hits the brine draw cycle?
    Jan 2013
    Salt Lake City
    I do get a brine draw (as I disconnect the tube from the venturi I feel suction). The figure 8 seal was replaced along with all the other seals and I made sure it was positioned correctly. Not sure about the water flow slowing down when it hits the brine draw cycle - I'll have to check that.
    Nov 2010
    Ocala, Florida
    If you are getting a brine draw enough to remove the the brine, the resin may be bad and 13 years sounds like it would be. Are you getting a lack of water pressure sometimes?
    DIY Junior Member Servallwater's Avatar
    Jan 2013
    Las Vegas, NV
    Definitely could be resin but I wanted to check with you and see if the unit is regenerating when called for. Northstar is most likely a metered unit but 13 yrs old could be a day timered system. If the meter is not metering your water, the unit may never come on and that could also be a problem. You should be able to set the unit to run an "extra regeneration" from the button on the front display. Since you do have good brine draw you should see the salt being consumed over a period of time also.
    Jim Owens
    Servall Water Conditioning
    3065 N. Rancho Dr. Suite 142
    Las Vegas, NV 89130
    www.serveallwater.com
    702-737-1957
    "If we cant fix your problem, you don't pay anything!"
    Servall Water Conditioning has been servicing the Las Vegas valley since 1978.
  1. Northstar water softener ?
    By crazyeyes in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-31-2011, 07:20 AM
  2. Water tests soft but doesn't feel soft.
    By ninefall in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-06-2010, 07:54 PM
  3. Northstar water softener
    By MiddleAgeSoftie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-28-2010, 06:52 PM
  4. What about Northstar softeners?
    By tmp9a59 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-08-2009, 06:37 AM
  5. What about Northstar softeners?
    By tmp9a59 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2009, 04:26 AM
