Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Weil-McLain Ultra 80 series 2 Boiler failed Sunday
  1. #16
    FWIW, my city's dump lets residents recycle antifreeze. I think they have a max deposit, though. It's mostly setup for recycling automotive antifreeze. You may try calling your local dump - if they won't take it, they may know someone locally who will.
  2. #17
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    I am still working that. Unfortunately I have no way to transport the barrels. But that also must be resolved.
  3. #18
    Apr 2006
    Washington
    My county dump only takes auto antifreeze and only 5 gallons/month. Not useful. A commercial processor will take it. $190/drum and I don't get my drums back.
  4. #19
    DIY Junior Member Failure2Comply's Avatar
    Sep 2012
    Virginia, USA
    Sorry for the issues that you have, Weil McLain makes some great standard boilers. I would NEVER buy any boiler with an aluminum heat exchanger, stainless steel is what I would choose. Those high levels of antifreeze impede your heat transfer and the needed concentrations of propylene glycol costs are just too high.
  5. #20
    Apr 2006
    Washington
    Thanks, I know that now. The Aluminum core appears to be OK in these boilers beginning with the series 3. And Al was the only choice in the WM. I was leery of Al at the time, but was convinced they had it handled. One of the things I thought about was the prevalence of Al engine blocks and antifreeze combinations. I had originally specified another small boiler with SS core, but I did not like the reports of a large number of assorted failures in the field. I also had no idea of the cost of the antifreeze and disposal. There were much more expensive brands, but the WM seemed to be better suited at the time. The problem in the Ultra series 2, as I understand it, was that the condensate was not draining as it should. They have a 15 year warranty and, in my experience, make every effort to honor it quickly if there is a problem. WM and their reps have been quite helpful and with the failure described, did not quibble about it; they just replaced it. They did not even want the core back. Just pictures of the unit. Which saved a bit more hassle. Would I rather it had not happened: you bet.
    I never viewed the lower heat transfer rate of 30% antifreeze as an issue. A bit longer pump run time and the control system controls water temp pretty well based on results in the load areas. In a closed loop (control wise) it just is not really a problem.
    A larger issue is to get a good constant pressure on the loop supply independent of flow so the controllers can get a real and stable reading of how fast a load heats.
  6. #21
    Not sure how long it might take, is if you let some of the water in the antifreeze mix just evaporate...you might have less to dispose of. NOw, the stuff can be toxic to animals, so if you have any around you want to keep, it would need to be placed somewhere they couldn't get to it. The issue with Al is that it expands and contracts a lot with temperature change. This can play hell with seals. If things aren't torqued properly, it could overstretch a connecting bolt, and when it cools off, now you have a leak.
  7. #22
    Apr 2006
    Washington
    Thanks. That is on my list for this summer. My heating guy suggested it.
    Actually the stuff in hydronic systems should be (and mine is) propylene glycol. It is not toxic. It is actually used as a food additive. Even with whatever additives are in there the manufacturer considers it non-toxic and the MSDS reflects that. Unfortunately this has not impacted how the state views the material.
    I am thinking maybe a little fountain pump and fountain. Spray the stuff from the drum bung into a pan mounted on the drum, drain to drum; repeat. Screen around it to keep critters off. And maybe something to mediate wind drift. Could power it with a small solar panel. On second thought, we have no sun here. Whatever. Maybe just run it down a filter/evaporator mat like a swamp cooler. If it does not clog the media, it would be a lot simpler. I will work something out. Anyone know of a fish that likes propylene glycol? Or how to train a slug to eat it. Them I have a lot of. Or would anyone like some used antifreeze? I would let it go real cheap.
    I saw some evidence of your point of expansion/contraction. I had to remove the cover from the heat exchanger for pictures. A couple of the nuts were only finger tight at best. They have a gasket in there, but there was evidence of soot that had escaped around some of the bolts. The entire boiler cabinet is the combustion air plenum, so a bit of leakage in the core would probably not be important. That may be why they did it that way. That was the only area that fittings seemed to have loosened or leaked. And I wonder if it was more of an assembly quality thing than expansion and contraction.
  8. #23
    The bolts need to be torqued very carefully. Proper tension on the bolt stretches it a bit, but still within the limits of the expected variance based on the expansion/contraction of the material it is holding (at least in theory). This assumes the proper bolt was specified and it meets those specs. It also assumes it wasn't deformed by over-torqueing it (it can lose its resiliency and be work hardened, causing things to fail). Get this wrong, and it can over stretch the bolt, and it no longer can respond to the material being held together properly. Not getting it tight enough, it will work itself loose. Think of threads as an inclined plane - things will go 'downhill' (loosen) if they aren't deformed or produce enough friction from the proper torque. There's a lot of science in this that isn't particularly critical on some things, but can be disastrous on others.
  9. #24
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    There was then and continues to be an aluminum specific anti-freeze now more deliberately specified by manufacturers and distributors of the Weil McLain Ultra. I have replaced many Ultra heat exchangers here in Minneapolis. They were all covered under warranty and they all were charged with the wrong antifreeze. Most certainly did not need antifreeze at all unless you think the garage loop will surely freeze up...and the sky is falling.
    It makes no sense to me to compromise the pump and thermal efficiency of a condensing boiler for a whole house to safeguard a heated space.
    Naturally, snow melting and green houses warrant their own sub-assembly.
  10. #25
    Mar 2011
    Minneapolis
    Why was anti-freeze installed in the system?
    All aluminum heat exchanger boilers require propylene glycol mixed for the purpose.
    Small claims.
    Your contractor is responsible for the proper application of the boiler and components.
    You are responsible for the proper "annual" maintenance of your boiler, which would include testing the pH and correcting any shortcomings. This is especially true if you use anti-freeze in a residential heating system.
  1. Weil-McLain Ultra Boiler
    By jadnashua in forum Plumbing Forum Discussion & Blog
    Last Post: 12-14-2010, 10:18 PM
  2. Weil McLain Ultra boilers
    By therinnaiguy in forum HVAC Heating & Cooling
    Last Post: 03-04-2008, 08:59 AM
  3. Weil-McLain Ultra 105 PARAMATER Settings
    By bmclaug264 in forum HVAC Heating & Cooling
    Last Post: 02-08-2008, 04:41 PM
  4. Weil-McLain Ultra 155 and purging air out of system
    By marklevinson1 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2006, 05:14 PM
  5. Weil-McLain Ultra Boiler
    Last Post: 09-23-2004, 06:48 PM
