Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Culligan Super S not pulling bleach
  1. #16
    Dec 2009
    Alaska
    The bed could be getting close to needing a change out, one good sign is the with the water at the same quality and usage the same the system has to go more often for the water to be treated.
    Yours would be about 10lbs of fine pea gravel or some thing along the line of #20 and then about 1 cubic foot of carbon, at least I think that is what culligan uses in systems like yours.
    The amount would depend on the size of the media tank under the control that you have worked on.
  2. #17
    DIY Junior Member jreed's Avatar
    Jan 2013
    MD
    Ill have to check the manual to see if it says in there. I didnt know if it was specific to the unit or specific to my water.
    I see now why you said there would be two pieces to the injector assembly. I was pulling out the injector, not the injector and holder.
  3. #18
    Dec 2009
    Alaska
    The media tank is most likely 10" across and 47" high?
    It is good that you are learning about the parts on the system.
  4. #19
    Jan 2013
    MD
    Actually its 10" across by about 54" tall.
  5. #20
    Dec 2009
    Alaska
    With the 10x54 that would be 1.5 cubic foot of carbon and about 13lbs of the very small gravel.
    Now my thought would be that you the owner has a right to know the media that is in use, not the Corp name like Culligan but the data sheet and the street name of the media.
    It could be that they are using the Centar Carbon... little spendy but good and if your system has gotten a number of years... say 10 then I would stay with the same type of carbon... it should be cheaper than the Culligan bags ....
  6. #21
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    The media for these tanks is Centaur Carbon. If it is the newer style with a center opening tank then you simply need to dump out old media, add gravel bed and appropriate amount of centaur (1 1/2 cu ft for 10x54 tank), being careful to not get anything down the distributor tube/manifold. If its the old style tank it would need to rebed by the dealer.
    RJH2O
  1. Bleach in Electrical outlets
    By windsmith in forum Electrical Forum discussion & Blog
    Last Post: 07-17-2011, 09:07 AM
  2. New Well, Bleach Added - Help!
    By Springer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-29-2009, 06:34 PM
  3. How to Bleach Wood
    By Blumengarten in forum Remodel Forum & Blog
    Last Post: 05-27-2009, 04:04 AM
  4. Problems with well after attempting to sanitize with bleach
    By NewHomeOwnerinPA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-28-2007, 11:38 AM
  5. Bleach in your toilet?
    By bobinparma in forum Toilet Forum discussions
    Last Post: 07-23-2007, 09:39 PM
