Results 1 to 2 of 2
Thread: connecting pvc to abs for vent
    DIY Junior Member NewGuy's Avatar
    Jan 2013
    Washington
    Default connecting pvc to abs for vent
    Is it possible to connect PVC to abs for a vent using threaded connections or transition glue. This would only be done in the horizontal section of the.vent 6" above a standpipe. I can not find 1.25" abs pipe.
    The smallest ABS size is 1-1/2"
    You can use a Mission Coupling, CK115,
    1-1/2" CI, PL or ST to 1-1/2" COPPER or 1-1/4" PL
  1. Question about connecting 2" wet vent to the 3" branch that it will serve
    By James Andereggen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2012, 12:40 PM
  2. Connecting New PVC Pipe Vent to Existing Cast Iron Vent Pipe in a Wall for Toilet
    By DanMcD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2012, 10:40 AM
  3. connecting rough-in 3rd level shower, sink and toilet vent stack
    By ajerome44 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2007, 10:40 PM
  4. Proper method of connecting to vent
    By PATNJ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2005, 07:49 PM
  5. Drip from vent pipe connecting to kitchen drain
    By ks cowboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2004, 09:45 PM
