Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Separate hot and cold water valves
    DIY Junior Member bpap's Avatar
    Apr 2010
    MA
    Default Separate hot and cold water valves
    I have a bath/shower with separate hot and cold water valves and a third one that is a diverter to switch between the shower and the tub faucet. Recently I had a steady dripping from the faucet so I changed the stem washer. I also tried to change the valve seat, but apparently I ended up stripping the seat as the square hole became rounded and I was no longer able to remove it.
    I called a professional to look at it and he was also unable to remove the seat. He indicate the only option was to replace all three handles with a single handle and either tile over the holes or use a conversion kit with a plate that covers the holes. He wanted to use a Symmons conversion kit. My understanding is that apparently it is against code to have separate hot and cold valves these days in order to protect from scalding.
    My questions are:
    1. Is there no option to have 3 separate handles/valves in any form? I really prefer this older look and would like to preserve it if at all possible.
    2. Is there any way to remove the broken/stripped seat? The plumber indicated he could try an E-Z out, but the ones he had were too short. If I could find one that was about 5 inches long (to reach all the way into where the seat was) that I could try that, but there was no guarantee it would work.
    My apologies if I have used ay incorrect terminology.
    Thanks for any suggestions or help you can offer.
    The problem with those seats is that some tools tend to bottom out at the back of the valve, before fully engaging. If your valve is a typical like PP, and you used an un-modified 3-step wrench or tapered wrench, that is how you damaged the hole.
    At this point, a #6 Easy-out may work. I think some of the other guys may have other hints. Not that installing a new pressure balanced valve is a bad idea...but you can save a lot of money for now if you can get the seats out.
    Apr 2010
    MA
    Thanks for the suggestion. Is there a #6 Easy-out that is longer than a typical one, which I think is usually just 3 inches or so long? I suppose I can look around to see what is available. I would need one that was about 5 inches long just to reach in far enough to access the seat and have a little extra to grab onto. As you also indicate, the plumber did mention that there was the risk of bottoming out at the back of the valve (and possibly doing even more damage).
    And yes, the other aspect is that I think it would be a few hundred dollars to install the pressure-balanced valve vs a few dollars for a new seat.
    If there are any other hints or tips from others out there, please let me know. Thanks.
    Many screw extraction devices can use an extension from a socket wrench set, or if a weird size, an extension with a socket on it (you'd need a 12-point socket to engage the square head). Sometimes, you have to grind the end off the thing so it can fully engage before the end pokes a hole out the back of the valve. There are some valves with multiple handles - volume, temp, divertor, but most are single handle as it's less expensive to meet the anti-scald requirements and pretty trim and handles cost more to produce the more you have.
    Apr 2010
    MA
    OK, thanks, I think a socket wrench with extension would work. I'm not sure I would be able to grind off the end as I assume an extractor is made of some sort of hardened steel. I'm guessing some sort of special grinder would be needed?
    I really would like to keep what I already have in place and working. It seems like a shame to completely replace something that has worked for so long because of one small part.
    If you have a "tempering" valve, that makes the three handle legal.
    You can dial them from 75 to 120 degrees
    It mixes hot and cold, blending the output.
    It's becoming very hard to find anyone making a three handle valve anymore. Sometimes it's better to bite the bullet and pick up something that looks old or traditional, and has the temperature protection built in.
    Apr 2010
    MA
    Thanks for the response. I've always been a bit unclear on exactly why separate controls are not allowed. I am pretty sure I do have a mixing/tempering valve just off the boiler connected to the hot water line, and the water never gets extremely hot even when I have only hot on. I have included a photo. In that case would it be possible to replace the entire valve if the seat cannot be removed??? The plumber that looked at it had indicated this was not an option because it would be against code. But perhaps if I show him there is already a mixing valve in place it would be ok? Let me know if I am incorrect about the image below being a mixing/tempering valve.
    I think, to qualify, there must be a tempering valve for the specific fixture, not for the whole house (although that is also a good idea and required where I live). The valve at the WH outlet is typically set around 120-degrees F, the safety stop for a tub/shower is usually 105-degrees or so (but can be overridden). That extra 15-degrees or so can mean the difference of being scalded or not. Children and older people have thinner skin and can get second degree burns at 120-degrees.
    Apr 2010
    MA
    OK, got it. Thanks for the information about the tempering valve being required for the specific fixture. In that case is it possible to simply add another tempering valve for the hot water control in the shower/bath and resolve the issue that way?
    If the tempering valve prevents scalding, you're Golden.
    My mothers 95. I installed her's at the water heater in case she takes a bath.
    She also has pressure balanced showers, but that's no help if she uses the deep tub. That's what the tempering valve was for.
    That low a water temp is insufficient for things like the dishwasher (unless it has a water heating feature, some do) which doesn't work well unless the water is like 130-degrees or so. Most people don't use hot in the washing machine, but 105 won't make even the warm setting very warm. So, from a practical point, a whole house tempering valve may not be the greatest solution for solving the bath fixture, even if code isn't impacted.
    Most tankless heaters can't be set above 120 degrees.
    Taking a 50 gallon tank heater, setting it at 160 degrees and then tempering it down to 120, makes it seem like a 75 gallon tank.
    My dishwasher and my mothers both have high temperature water heating for the dishwasher. And washing with warm water has never been in issue.
    Some people prefer to wash with cold.
    Apr 2010
    MA
    Just to be clear. When you say "you're Golden". Do you mean it in a general sense as far as safety, which is good of course? Or are you saying that with the whole house tempering valve in place I don't need to have an additional tempering valve for the specific fixture (the hot water valve at the bath/shower in this case) to meet code.
    Thanks.
    Gold is good.
    UPC 414.5
    Limitation of Hot Water in Bathtubs and Whirlpool Bathtubs. The maximum hot water temperature discharging from the bathtub and whirlpool bathtub filler shall be limited to 120 degrees F, by a device that conforms to ASSE 1070 or CSA B125.3. The water heater thermostat shall not be considered a control for meeting this provision.
    UPC 418.0 Mentions pressure balance, thermostatic, or combination pressure balance/thermostatic mixing to prevent scalding and shower shock. And again mentions a 120 degree limit.
    The advantage of a modern pressure balance or thermstatically controlled valve is that should there be a condition that disrupts the flow on one side or the other, the temperature doesn't change much. On a pressure balanced valve, a sliding valve called a spool valve moves towards the low-pressure side, shutting down some of the flow from the higher side, maintaining the relative volumes of the hot and cold which keeps the temp fairly even. A thermostatically controlled valve uses various means to maintain the outlet temperature based on varying inputs. A tempering valve external to this arrangement will limit the max temperature that can be released, but will not prevent the potential shock of going from 'normal' showering temperature to a potentially near max or quite cold spurt. that is where a modern anti-scald valve comes into play...it is safer since the shock of a wide temperature variation can be as disruptive as an overtemp situation.
    So, limiting max temp is only part of the safety issue, but may be enough to pass local code inspection. Maximum safety calls for a newer valve...your level of comfort may vary.
  1. How to separate PVC pipes
    By mntentman in forum Plumbing Forum Discussion & Blog
    Last Post: 02-01-2010, 06:21 AM
  2. Which is better -single shower or separate valves?
    By 12fingers in forum Shower & bathtub Forum & Blog
    Last Post: 11-15-2008, 04:06 PM
  3. Can I separate aan ABS fitting?
    By pjb in forum Shower & bathtub Forum & Blog
    Last Post: 03-14-2008, 04:48 AM
  4. hot cold shut off valves...
    By chris fox in forum Remodel Forum & Blog
    Last Post: 01-15-2008, 02:14 PM
  5. Juncture of tub and separate shower
    By Access for All in forum Shower & bathtub Forum & Blog
    Last Post: 10-22-2007, 07:13 PM
