Results 1 to 10 of 10
Thread: air in pipes?
    DIY Member billfig's Avatar
    Feb 2011
    upstate NY
    Default air in pipes?
    2 weeks ago I drained HW tank and flushed repeatedly to remove all the anode rod junk (15x) I installed an anode rod. I also drained bladder tank and installed a new inline cartridge(12") and the water has been great! My shutoffs were somewhat seized from age/gunk? and I loosened the nuts to get the valves to work. Ever since all this I'm picking up air which is present from any faucet when first run? It's not as bad when first purging air after an open system but it annoys me. I have no leaks though? I would think to draw air I would also see a leak somewhere? I have tried "snapping" the relief valve on HW tank too..Puzzled?
    Depending on your water chemistry and the type of anode material, some can produce gas in the water. You may need a different type of metal on your anode.
    Feb 2011
    upstate NY
    Oh...I didn't know that? I know the 6 yr tank has lasted 12 yrs.now I did have the co. send me another anode when new for rotten egg smell and kept the old one which was new anyway? That is how I got the current replacement I used.
    Feb 2011
    NW Ontario, Canada
    Are you on municipal or well water? Do you have an iron filter or softener?
    Sometimes air may be en-trained in the water as part of the treatment process. When aerated water is heated, it releases the air. That is why a hot spell can kill a lot of fish.
    Many iron filters work by aeration. Water softeners that don't properly shut off the brine line can draw in enough air to later cause spitting at faucets.
    When you drained the bladder tank, did you make sure it had the proper precharge or did you trap air above the water? Did you verify that the bladder is sound?
    Feb 2011
    upstate NY
    I'm on a well, just a small whole house sediment filter($50.00 model) to a Sears water softener(new last year) I just drained the bladder(new a year or 2 ago) and then refilled..?
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by billfig View Post
    That statement in and of itself raises doubts. The way a bladder tank works is that with a proper precharge, it is nearly empty at the kick-in pressure so there really is not much of anything to "drain". If the precharge is not properly maintained, the bladder may rupture or fail prematurely.
    Is your well pump above ground or submersed? If above ground, you could have a suction-side leak.
    Feb 2011
    upstate NY
    5yr.old Gould submersible in a 80' well. I just turn the power off to pump and drain tank then close petcock/valve, and fill tank..? I'll go check my psi precharge now...just checked tank, 30psi/ cut-in 32psi just as it should. I did just check on the old but upgraded anode which American Water Heater of TN. still sells, an aluminum/zinc/tin one for $50.00 which lasted 12 yrs. and did remove odors. I just used the original one from tank which doesn't seem to have any odor effects now?? glad I kept it. This isn't a big deal and most would never even know but since I do all the work and maintainance...I know it aint 100%..but very close! lol
    Feb 2011
    NW Ontario, Canada
    OK, then that leaves the anode or the softener as likely suspects. Watch the softener as it is nearing the end of the brine draw. If is sucks in a lot of air, that air will sit at the top of the resin tank and slowly get absorbed into the water. The heat will then drive it out and collect at the top of the tank.
    Feb 2011
    upstate NY
    Yea, OK.. in fact, when I did the servicing I also removed the venturi/nozzle assy and cleaned. I think I'll check and make sure all is correct there too while I'm at it. Believe it or not, I did think for the next few days if the softener was working cause the salt level hadn't seemed to drop(maybe nuthin) I was checking it daily, then I did notice a drop after maybe 4 or 5 or 5-6 days. The softener itself I just renewed 2 yrs. ago iirc. I must admit too, when I was tightening the filter cartridge housing using my 2' channel locks I did hear a pretty good snap/crack (I already have the barbs or whatever broken off) but I had no external leaks so I figured I'm good to go...for now..
    DIY Junior Member bookemdanno's Avatar
    Jan 2013
    If it is the water softener, you will get the air only in the cold side and only the morning after regeneration. Once the air is washed out, you will not get it again until the next AM after the next regeneration.
  1. Witching for pipes Video, this is how you find underground pipes.
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 05-16-2010, 11:46 AM
  2. What are these pipes?
    By Reno_Now in forum Plumbing Forum Discussion & Blog
    Last Post: 06-03-2008, 07:22 PM
  3. What are these pipes?!
    By photojeff3200 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-11-2007, 10:35 AM
  4. Air in pipes
    By Choral in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-30-2007, 06:42 AM
  5. Air in the Pipes
    By rburt5 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-26-2006, 05:41 AM
