Results 1 to 11 of 11
Thread: Insulation where floor joists overhang foundation
Threaded View
    DIY Senior Member pmayer's Avatar
    Jul 2006
    Minnesota
    Default Insulation where floor joists overhang foundation
    I am continuing my basement remodel and following the great advice that I have received here in the past regarding insulation. In fact I should mention that the previous basement room that I finished is by far the most comfortable room in the house thanks to you guys. In the area that I am currently finishing there are a couple places where the floor joists extend a couple feet past the foundation wall (one is for a bay window and the other is for a patio door bump-out thing. Currently there are just unfaced fiberglass bats in these cavities, installed with the bats laid flat apparently to allow some air flow and to make a nice comfy home for mice. Now that I am replacing all of the fiberglass that is up against the rim joist with Thermax (inspector won't allow unfaced XPS), but I won't be able to reach in far enough to install this on the protruding rim joist in these two areas. So, my question is, how should I insulate in these areas? Do I need to use spray foam? Or replace the unfaced bats with paper back ones? What about the air flow that appears to be currently in place; is this important?
    Also, on the exterior side of 2 of my foundation walls there is a layer of 6 mil plastic directly against the foundation, and 1" of XPS on the outside of that. Am I OK to install another 1" XPS against the inside of the foundation wall? The other wall that I am finishing had no XPS or plastic on the outside and I am adding 2" of XPS on the inside foundation wall as I did on my previous remodel.
    Paul
  1. XPS basement insulation and foundation sill plate
    By pex006 in forum Remodel Forum & Blog
    Last Post: 10-12-2012, 04:42 AM
  2. Shower drain between, then under floor joists...
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 10:55 AM
  3. Floor joists near flange
    By gbh in forum Toilet Forum discussions
    Last Post: 12-23-2008, 06:22 AM
  4. drilling floor joists...
    By coach606 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2006, 07:35 PM
  5. 3" pvc throught floor joists
    By Plumbrobert in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2005, 07:09 AM
