Results 1 to 5 of 5
Thread: Bathroom Supply Lines Entry Point
    DIY Junior Member nelsongg's Avatar
    Mar 2008
    VA
    Default Bathroom Supply Lines Entry Point
    I am remodeling an upstairs jack 'n' jill bathroom. I am custom building a 36" floating vanity. The new vanity will be placed in the same place as the old one. The back of the vanity will mount against an outside wall and the left side of it will mount against an inside wall. The problem is currently the supply lines come up through the floor (I'm assuming to prevent freezing) and that will kind of ruin the look of the floating vanity.
    What I would like to do is reroute these lines to enter the new vanity through the inside wall that the vanity will be attached to on the left. This would actually work well for positioning since I plan to mount an undermount round sink 3" off the left wall and 3" from the front edge to maximize limited counter space to right side. I plan to mount the faucet at the 10:30 position to the sink which would be right above where the supply lines would come into the vanity from the side wall.
    Basically, is it OK to have the supply lines come into the side of the vanity?
    If there are any other problems with this, please criticise (I'm married, I'm used to it).
    Thanks,
    Greg
    Jan 2008
    There is nothing to say that you cannot run the supply lines any which-way, as long as they are properly supported and protected from freezing.
    Just curious. I've not heard of the 10:30 position before?
    quote; I've not heard of the 10:30 position before?
    Halfway between the 10:00 and 11:00 positions, which make make it a very precise location.
    Supplying waste and water lines from the side are just fine.
  1. Replacing old galvanized water supply line from meter to entry at house
    By k9mlxj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-26-2013, 05:03 PM
  2. Water Supply Lines for Bathroom
    By KShirriff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-02-2012, 12:36 PM
  3. Flexible (roll) copper for bathroom supply lines?
    By Flot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2010, 06:09 PM
  4. heights for supply and drain lines for bathroom sink
    By Steve_P in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2010, 01:27 PM
  5. Need help with supply lines to bathroom
    By redgreen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-24-2008, 02:30 PM
