Results 1 to 3 of 3
Thread: How to un-connect a kitchen side spray hose from a plastic fitting under the sink
    DIY Junior Member Tom Hoffman's Avatar
    Nov 2008
    Orangevale, CA
    Default How to un-connect a kitchen side spray hose from a plastic fitting under the sink
    The side spray line "keeper" (where the line comes out of the sink hole) broke. To repair it I need to remove the side spray hose. I can't figure out how to un-do the spray line hose. See picture - this is looking straight up under the sink. It is the black line on the right that goes in to the gray plastic fitting. The silver braided line at the top is the water supply. Any help is appreciated.
    Tom Hoffman
    Orangevale, CA
    You push up on that "grayish" ring around the brass stub and then pull the brass stub out., although, I would take the spray head apart, and drop the hose down through the guide.
    Nov 2008
    Orangevale, CA
    Thanks HJ. In a million years, I would have never figured that out!
  1. Water softener drain connect to kitchen sink?
    By DougDoingRemodel in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-18-2010, 12:03 PM
  2. Inexpensive sink side spray heads
    By dellphinus in forum Plumbing Forum Discussion & Blog
    Last Post: 01-29-2010, 06:52 AM
  3. Tub drain and stack side by side... how to connect
    By louk in forum Plumbing Forum Discussion & Blog
    Last Post: 07-12-2008, 08:55 AM
  4. need diagram for plumb on a double kitchen sink left side 10" right side 8"
    By cottagepeople in forum Plumbing Forum Discussion & Blog
    Last Post: 01-24-2007, 01:04 PM
  5. Kitchen sink trap on side or center.
    By paul roney in forum Remodel Forum & Blog
    Last Post: 12-24-2005, 10:52 AM
