Results 1 to 5 of 5
Thread: GE Smartwater Softner
    DIY Member Phillbo's Avatar
    Nov 2008
    Arizona
    Default GE Smartwater Softner
    My GE Smartwater softener is filling full of water in the tank where I add the salt. It's never done this before. Any suggestions on areas to investigate? The water is about 1.5' - 2' deep.
    Thanks for any insight you can offer.
    Nov 2010
    Maine
    Check the Venturi and the brine line fittings
    Nov 2008
    Arizona
    Pulled the Venturi apart and everything looks fine. Anything else that could cause the salt tank to fill with water?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Put the unit into a braw cycle. Disconnect the brine line from the valve. If water is dripping out the connection, check the rotor, rotor seal and fig 8 o ring under the main cap.
    DIY Junior Member Servallwater's Avatar
    Jan 2013
    Las Vegas, NV
    Were you able to check the brine draw? If everything on the valve looks ok and you have brine draw there may be a leak somewhere. If you run the system through a complete regeneration does the water level in the brine tank drop? If it does drop after this but slowly fills back up you may have a leak from the mineral tank or the valve. Sometimes the leaks are so small that it takes a while to notice. Hope this helps.
    Jim Owens
    Servall Water Conditioning
    3065 N. Rancho Dr. Suite 142
    Las Vegas, NV 89130
    www.serveallwater.com
    702-737-1957
    "If we cant fix your problem, you don't pay anything!"
    Servall Water Conditioning has been servicing the Las Vegas valley since 1978.
  1. Low Pressure Out of GE Smartwater Softener
    By Phillbo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-06-2011, 08:58 AM
  2. smartwater not drawing brine
    By rightlane in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-28-2010, 06:40 PM
  3. I have a new softner but???
    By MOVIE GUY in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-28-2010, 12:08 PM
  4. Softner Recomendation
    By Peter Griffin in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-07-2009, 09:24 AM
  5. water softner
    By ally68 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2006, 05:13 PM
