Results 1 to 2 of 2
Thread: Rear discharge Toilet help
    DIY Junior Member jikoch's Avatar
    Dec 2012
    Iowa
    Default Rear discharge Toilet help
    I have a cleanout 11" off the basement floor in a finished basement wall. This main is coming straight down from a bathroom directly above on the first floor.
    Id like to place a rear discharge toilet up against that main line in the basement ( where the cleanout is located ) and run a rear discharge toilet into that main.
    Does this seem like an acceptable option for me? Any concerns?
    Your help is greatly appreciated.
    Whenever the upstairs toilet is flushed, it's going to burp air into the downstairs bowl, and you will lose water in the bowl. Flush the upper one a few times, and you won't have any water in the lower toilet bowl.
    If you intend to add a toilet below the upstairs plumbing, it will need to be vented "before" it enters the waste stack.
  1. Is this a rear discharge toilet?
    By chmedly in forum Toilet Forum discussions
    Last Post: 07-06-2012, 11:23 PM
  2. Flow Problem mystery with rear discharge toilet
    By FishAllThe Time in forum Toilet Forum discussions
    Last Post: 12-31-2009, 08:31 AM
  3. Rear discharge toilet seal options
    By doitright in forum Toilet Forum discussions
    Last Post: 01-25-2008, 04:37 AM
  4. Rear discharge toilet mount question
    By ashbrook in forum Toilet Forum discussions
    Last Post: 10-06-2006, 08:39 AM
  5. tiling rear discharge toilet
    By astro46 in forum Toilet Forum discussions
    Last Post: 12-08-2005, 05:12 AM
