Results 1 to 5 of 5
Thread: Overload trips about once a week.
    DIY Junior Member rocklin662's Avatar
    Dec 2012
    Roseville, CA
    Default Overload trips about once a week.
    In the past three weeks the overload on the bottom left of the motor control has tripped while someone was taking a shower. It is a 2hp submersible pump on 2" ? pipe in a 6" well casing. About 2 feet of the casing are sticking out of the ground and the pump control box is mounted on top of the casing. The well was drilled in 1979 and from the documents the depth was 210', the static water level was 115' and the 4 hour flow was 30 gpm. The control box is a Franklin Electric 2823018110. I downloaded the manual from Franklin Electric and will run through the tests on Tuesday. The control box is mounted in direct sun and the manual cautions against that. It does get fairly hot here on the edge of Sacramento.
    Moderator valveman's Avatar
    Mar 2006
    Tripping an overload while taking a shower usually means the motor is tripping out from cycling on and off. It could just be a weak start cap or relay, but I am guessing you should be prepared to replace the pump/motor.
    Dec 2012
    Roseville, CA
    Did a bit of testing today. Using Min/Max on Fluke 87 meter reading as follows. Line voltage dropped from 241.4 VAC to 234 VAC when the pump turned on. I would have expected the current on the red (start) conductor to go higher. Both capacitors appear to be open. The run capacitor is in a rusty metal case but the start capacitor appears to be newer. Coil tests ok.
    Measured:
    Color Start Run
    Red 4.0A 3.3A
    Yellow 44.8A 12.8A
    Black 44.0A 11.8A
    From Table:
    Color Full Load Maximum Load
    Red 2.6A 2.6A
    Yellow 10A 13.2A
    Black 9.3A 11.9A
    Mar 2011
    Houston, TX
    I would replace the caps or at least check them.
    Your readings are a little confusing, or maybe they are wrong.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Dec 2012
    Roseville, CA
    Got both capacitors for $26. Been good for a month. Thanks for the help.
  1. CU301 with red overload light constantly on
    By tommyboy2010 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-12-2012, 06:10 PM
  2. Breaker box overload?
    By Mickey Mowery in forum Electrical Forum discussion & Blog
    Last Post: 06-17-2010, 05:54 AM
  3. Thermsl overload on pump
    By Ford2001 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-14-2009, 06:22 PM
  4. Thermal overload
    By sparker in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-24-2009, 08:06 AM
  5. off on thermal overload
    By Rando Tyler in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-04-2007, 05:57 PM
