Results 1 to 6 of 6
Thread: Metal Shower Spout/Pipe to CPVC Fitting
    DIY Junior Member
    Dec 2012
    Pennsylvania
    Default Metal Shower Spout/Pipe to CPVC Fitting
    I have cpvc pipes. At the top there is a threaded fitting with a rubber gasket inside. My question is how to get the angled shower head pipe in so that it is tight enough and lined up. Mine needs to be tighter but would need another full turn to line it up right, I am afraid it will either destroy the rubber gasket or break the fitting. Thanks in advance for any advice.
    Jan 2008
    Most people who have done some plumbing know better than to use plastic threaded fittings because of the likelihood of cracking. I would never use CPVC on a shower riser.
    The only thing you can do is try using a liberal amount of pipe dope on the threads and turn it in until it is fairly tight and facing the right direction. If that does not work, it's time to get out the saw for some re-work.
    Sep 2009
    Seattle. WA
    Thread tape will work a lot better than pipe dope for that purpose, especially the thicker pink or yellow tape.
    Jan 2008
    "Just enough" teflon tape would work, but too much might result in a cracked fitting.
    I have also seen a lot of shower arms with poorly cut threads- I have one laying here somewhere that looks like it has acme thread instead of pipe.
    DIY Junior Member
    Dec 2012
    Pennsylvania
    Thanks for all the help, I will try the teflon tape. Can't do anything about the riser being cpvc, it has been in there for years with no problems so far as far as cracking, etc. It doesn't leak as long as it is tight enough, the problem is the alignment is about 1/8 of a turn too far. If I do have to replace it I'll use one with the brass threads. Great forum, thanks all.
    Replace the gasket with a proper sized "O" ring and you will be able to compress it enough to be tight and aligned properly.
  1. What kind of Copper to CPVC fitting is this?
    By JerryR in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2012, 08:06 PM
  2. Metal verses Non-Metalic tub spout
    By jadnashua in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2010, 04:38 PM
  3. Transition fitting from CPVC to PEX
    By bingo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2008, 05:49 AM
  4. chrome gooseneck to cpvc shower fitting - how do I ensure it doesn't leak behind the
    By Honest Bill in forum Shower & bathtub Forum & Blog
    Last Post: 11-01-2007, 04:31 PM
  5. connect cpvc to metal shut off valve
    By Gwynnefar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2005, 09:00 PM
