Results 1 to 3 of 3
Thread: 2" shower p-trap with our without union?
    DIY Junior Member Curtis Myers's Avatar
    Nov 2012
    Saskatchewan
    Default 2" shower p-trap with our without union?
    I'm installing a shower on my main floor and am wondering if I should use a p-trap with our without a union. The trap is accessible from below from the basement. From what I've read, it's not recommended to use the one with union. Thanks for your help.
    Jan 2008
    A 2" trap is easy to snake through, so I can't think of many reasons I would ever want to take it apart and put it back together. It would be another place to leak though.
    If it is a long run across the basement, you might consider adding a wye in the line for a cleanout.
    If you are looking for one more problem, then go for the union.
    Most codes want solvent fittings that are hidden because unions are always a problem later on.
  1. Leaking ABS P-trap union
    By nestork in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-28-2012, 06:45 PM
  2. 2" shower trap
    By drlcm-06 in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2012, 07:48 PM
  3. union trap fittings
    By mrd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2010, 05:22 AM
  4. Basement P Trap - 1 1/2" or 2" (Tub/Shower)
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2009, 12:34 PM
  5. Tank water heater- dielectric union? heat trap?
    By edwardh3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2008, 12:59 AM
