Results 1 to 3 of 3
Thread: interchangeability of toilet tanks
    Default interchangeability of toilet tanks
    American standard does make replacements for their tank model no.4036 are other tanks available as replacements
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    What toilet is that for? I have a Cadet 3 1.6gpf which came with their universal bowl which can also use their 1.25gpf tank. Then there's the rough in size, 10, 12 or 14". Each uses a different size tank. If you had a 12" rough in, if available, you could use a 10" tank to leave space behind it to the wall but less space on sides and higher also.
    Bill
    Just a DIY'r
    IF the distance between the two bolts is the same, and the flush valve opening is approximately the same distance from both the front and rear of the tank, then the tank will usually interchange. IF any of these dimensions is off, then the seat may not stay up, the tank may hit the wall, or it may not go down on to the toilet.
  1. How much do insulated toilet tanks really reduce condensation?
    By peggyk5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2012, 09:36 AM
  2. Tub Shower Stem Interchangeability
    By Bob Wells in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2010, 06:57 PM
  3. Help! Toilet tanks keeps leaking...
    By tbright in forum Toilet Forum discussions
    Last Post: 01-24-2008, 04:40 AM
  4. Alternative to 1.6 gallon toilet tanks?
    By John Strong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2007, 06:16 AM
  5. 2 HW Tanks in Parallel, Where to Tap Irrigation Line? Need for Expansion Tanks?
    By jluksic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2006, 04:46 AM
