Results 1 to 4 of 4
Thread: Kohler valvet question
    DIY Junior Member analogguy's Avatar
    Feb 2008
    California
    Default Kohler valvet question
    I have to replace a Kohler valvet stem assembly (hot side) and was wondering if there is a trick to installing it correctly. Should the valve be all the way open or all the way closed when installed? I've read somewhere that if done incorrectly the handle will just keep spinning and will not work. Thanks.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    keep the stem half closed. Tighten it by hand ensuring that the stem can spin freely until the bonnet is tight. Why not replace the hot and cold at the same time while the water is off? Do not apply any grease on the stem, have had them open by itself after using greaseon the stem (brass barrel type).
    Anything except "closed". You have to hold the stem while tightening the bonnet or it will open or close itself, depending on whether it is a right hand or left hand stem. If it opens, no problem, if it closes, you will NOT be able to tighten it properly.
    Feb 2008
    California
    Problem solved. Thanks to all..you guys are the greatest!
  1. Kohler question and TOTO
    By CPT in forum Toilet Forum discussions
    Last Post: 10-29-2010, 04:26 PM
  2. Kohler Valvet (I think) conundrum
    By jim baird in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-28-2009, 05:28 AM
  3. kohler tub and shower module question
    By jymbob in forum Shower & bathtub Forum & Blog
    Last Post: 04-06-2006, 05:47 PM
  4. question about waste drain for kohler tub
    By amyharvey in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2006, 04:46 AM
  5. Kohler Diverter Question
    By Odymon in forum Shower & bathtub Forum & Blog
    Last Post: 02-26-2005, 06:10 PM
