Results 1 to 3 of 3
Thread: Case toilet No. 3000
    DIY Junior Member jelynne's Avatar
    Dec 2012
    San Antonio, Texas
    Default Case toilet No. 3000
    The tiolet is discontinuted. We have replaced all parts and now it is broken again. It is wall hung and needs replacement. Any advise on where to fine a replacement wall hung toilet that is compatible?
    DIY Member stephenk's Avatar
    Nov 2012
    Plains
    Quote Originally Posted by Joe Six Pack View Post
    Ya mean not out the front?
    So Stephen, since the Case is a two bolt carrier, which brands are you talking about?
    I didn't google the toilet in question. I was simply trying to get more info to help the OP and mentioning there are wall hung toilets available from several brands. I didn't say they would be a direct swap.
    To the OP-
    If this is the toilet in question?
    There's probably some useful info in this thread:
    http://www.terrylove.com/forums/show...Mounted-Toilet
    Apr 2012
    New York, NY
    I have seen where HJ thinks that this is a great toilet.
    Because he knows what he is doing, he can easily and with just a few parts bring them back to life.
    You don't need to replace all the parts. You really just need to replace the moving parts. That means you don't need to get ripped off with the installation of a whole new expensive fill valve; just replace the few moving parts in it that need replacement. HJ says that any Briggs dealer can help you. Have a look at the thread SK cited above; it has all of HJ's recommendations, including the names of the parts that you can inexpensively replace.
    HJ also, in that thread, tells you what you need to do if you must replace it, because there is no direct replacement.
  1. Case 3000 Wall Mounted Toilet
    By batencio in forum Toilet Forum discussions
    Last Post: 04-10-2014, 10:08 AM
  2. Case 3000 1965 replacement toilet
    By Jack D. in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2012, 08:34 AM
  3. Need Some Advice on a Case 3000
    By maryann650 in forum Toilet Forum discussions
    Last Post: 01-14-2009, 07:19 AM
  4. Desparate for answers about Case 3000 toilet
    By Janine in forum Toilet Forum discussions
    Last Post: 02-26-2006, 04:43 PM
  5. Case 3000 toilets
    By Guest in forum Toilet Forum discussions
    Last Post: 01-24-2006, 05:33 AM
