Results 1 to 5 of 5
Thread: 3/4 to 1/2 valve/pipe for shower head
    DIY Junior Member tomdiy's Avatar
    Dec 2012
    nj
    Default 3/4 to 1/2 valve/pipe for shower head
    Shower installation with two shower heads each on its own volume valve. The supply into the kohler themostatic valve is 3/4 pex into 3/4 cooper into the valve, exiting the valve is 3/4 copper reduced to 1/2 copper then into each of the 1/2 volume valve and 1/2 copper out to the shower heads, both shower heads seem light on flow both hot and cold (Other fixtures on same feed are fine), Kohler says I should have keep it all 3/4 after the valve but don't most shower heads have to reduce to 1/2 at some point? I was going to replace the valve cartridge to see if it helped but figured I would ask for thoughts before spending the money. Thanks in advance
    Unless you removed the restrictor (some can be easily, some can't), each shower head is mandated to have a max of 2.5gpm. But, 1/2" pex might be hard pressed to provide 5gpm. The ID of pex is considerably smaller than that of copper in the same 'size' (which is the OD, not the ID). This is because copper is much stronger, so it can be thinner than pex. What's strange to some is that 1/2" copper is unlikely to be 1/2" ID and it is 5/8" OD, although it is much closer to 1/2" than pex.
    quote; What's strange to some is that 1/2" copper is unlikely to be 1/2" ID and it is 5/8" OD
    The i.d. is determined by the tubing's wall thickness. Type "K" with the thickest wall is ALMOST 1/2" i.d., about 1/40" larger than actual 1/2".
    Dec 2012
    nj
    Thanks, I guess I was not clear, the flow I am getting is less than I have from predominately 1/2 inch in the other bathrooms, why would 3/4 supply reduced to 1/2 for the last 10 feet of the run after a valve reduce the flow to less than a run which is mostly 1/2 inch
    Few valves' internal passages are the same diameter as the supply pipes. IF the pipe supplying and outlet of the valve are both the same size, the flow rate increases in the valve and it doesn't act like a restrictor much (the venture effect). If the outlet pipe is smaller, it stays slowed down and the valve is a real restriction to flow. The outlet of a faucet goes through the spout, which is usually unrestricted (well, it may have an aerator on it).
  1. Broke the shower pipe changing the head
    By ramzmusic in forum Shower & bathtub Forum & Blog
    Last Post: 12-17-2008, 07:56 PM
  2. Shower Pipe/Head question
    By mcasemo in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2007, 08:58 PM
  3. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
  4. Shower head pipe too close to ceiling
    By rzellmer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-26-2006, 03:58 PM
  5. Shower Head and Pipe replacement.
    By ROBSGUY in forum Shower & bathtub Forum & Blog
    Last Post: 03-27-2006, 04:53 AM
