Results 1 to 15 of 15
Thread: Wall Framing and Flooring over Subfloor
Hybrid View
    DIY Junior Member Schopsy's Avatar
    Dec 2012
    Western Wisconsin
    Default Wall Framing and Flooring over Subfloor
    As I mentioned on another thread, I am preparing to finish my basement. I am considering the following subfloor stackup:
    • Existing Concrete Floor
    • Delta FL Vapor Barrier
    • 1" XPS
    • 5/8" Plywood (Tongue and Groove)
    The finish flooring will, most likely, be vinyl plank in the living areas and ditra/tile in the bathroom.
    I have several questions:
    1. Does this subfloor stackup look reasonable?
    2. Can the Plywood be left floating in the living areas?
    3. Should the Plywood be Tapcon'd through the XPS to the existing concrete in the bathroom?
    4. Should the partition walls be built on top or next to the built up subfloor? (see sketch below). In either case the base plate would be fastened to the existing concrete floor.
    In the sketch below, I've shown "on top" as A and "next to" as B. If A is used, to the left would be an unfinished utility room with a dehumidifier to pull any moisture from below the Delta FL. If B is used, any moisture below the Delta FL have to absorb back into the concrete or into the base plates (which would be treated, of course). The exterior stud walls are in, so B will be used around the perimeter of the basement regardless.
    Name:  wall options.jpg
    Thanks in advance for your replies!
    Jun 2009
    Canada
    Don't use DELTA FL and XPS together.
    Frame after you finish the floor, it will be much better that way.
    You will need to tapcon the ply, it wont stay there floating perfectly without.
    Dec 2012
    Western Wisconsin
    6 mil vapor barrier, then?
    In the trades Dana's Avatar
    Jan 2009
    A 6 mil vapor barrier would be fine.
    The foundation wall also needs foam between the concrete & studs, as well as between the concrete & sub-floor edge.
    You have serious moisture trap risk to the plywood with vinyl flooring on top, which is also a strong vapor barrier. Using something more vapor open than vinyl for the finish floor is STRONGLY recommended.
    Dec 2012
    Western Wisconsin
    Thanks for the replies. Are there any "non-carpet" flooring options that would be suitable below grade other than carpet? My thought with vinyl was that it would be moisture tolerable, but I've kind of eliminated that line of thought with the plywood in the subfloor stackup.
    Dec 2012
    Western Wisconsin
    Dana, regarding the top vapor barrier, is the tile in the bathroom going to be a problem? Would I be better to use cement board rather than plywood in there?
    Thanks again!
    Jan 2008
    Jim, if Ditra is butted up against the walls and flooring goes over the top of it, where will the water vapor vent? I don't understand how it is supposed to work.
  1. Replies: 5
    Last Post: 03-31-2011, 05:48 AM
  2. framing for plumbing
    By vjames in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2007, 09:35 PM
  3. Another Framing Question
    By nursedoe in forum Remodel Forum & Blog
    Last Post: 09-19-2007, 10:10 AM
  4. Framing a bathroom
    By maahlgren in forum Shower & bathtub Forum & Blog
    Last Post: 11-24-2005, 04:21 AM
  5. Nailer for Framing
    By redneckplumber in forum Remodel Forum & Blog
    Last Post: 08-28-2005, 05:39 AM
