Results 1 to 5 of 5
Thread: Connecting to sanitary
    DIY Junior Member JeffreyLB's Avatar
    Dec 2012
    VA
    Default Connecting to sanitary
    Can the 2" drain line from a shower tie into the side of a horizontal sanitary line or does it have to tie into the top?
    The shower can tie into a horizontal waste line, but it needs to be vented before it does.
    Otherwise anything coming down the line can siphon the trap.
    If you have only a lav run with 2" pipe on that line, and that is vented, then it would be "wet vented".
    Most plumbers have those run in 1.5", so the waste to the lave would need to be pulled and upsized.
    Dec 2012
    VA
    Quote Originally Posted by JeffreyLB View Post
    The shower drain line will be vented before connecting to the sanitary.
    In that case, it's a wye fitting on the horizontal.
    If your question is asked correctly, then you cannot use a sanitary tee in a horizontal line, period.
  1. Sanitary Tee on it's back
    By edtuck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2012, 09:16 AM
  2. DWV Toilet to Sanitary t
    By moshetojinx in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2011, 06:51 AM
  3. Making an old well sanitary
    By riverside67 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-16-2009, 08:58 AM
  4. wye vs. sanitary-tee
    By SuperDaddy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2008, 11:20 AM
  5. Sanitary Tee on Back in DWV
    By plumbnut in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2007, 10:08 AM
