Results 1 to 5 of 5
Thread: Whether to caulk and scribe my vanity
    DIY Junior Member Buttonsrtoys's Avatar
    Nov 2012
    Nova Scotia, Canada
    Default Whether to caulk and scribe my vanity
    I'm finishing up an install of the vanity in the pic. The vanity cabinet and sink are fastened to the wall with lags in blocking and anchor bolts in plaster so it seems quite secure. I made sure the sink was level, but after the install I noticed that the floor isn't level, so the front of the vanity is 3/16" off the floor and the back sits on the floor. It's not enough to notice so I'm thinking of leaving it. I could take it off and scribe it, but its melamine and finished on the bottom, so ripping it and setting it on the floor seems like it would wick up lots of water and break apart.
    I'm curious for feedback if leaving it is the way to go. Alternatively, I could run a bead of silicone under it. If I go this route, should it be clear or white?
    Also, the sink top is rounded where it butts against the wall. Should that get a bead as well? White?
    Thanks in advance...
    Nov 2010
    Maine
    Caulk both, white
    Put some shims underneath the front before you caulk it (done right, the caulk would hide them). Otherwise, when/if someone leans on the thing, you won't be stressing the cabinet. It is designed to be sitting on the floor all around - you don't want it just hanging there from the back edge.
    Or put a white base shoe around the bottom of the cabinet.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Yes you need to caulk around the back of the sink to prevent water splash from running
    down between the sink and wall it calls for a water proof washable surface
    ie; water proof caulking
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Converting single sink vanity to double vanity
    By xceebeex in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2011, 09:22 AM
  2. another Single Vanity to Double Vanity thread, IPC
    By tekmassa in forum IPC Plumbing Code Questions
    Last Post: 06-05-2010, 01:30 PM
  3. another Single Vanity to Double Vanity thread, IPC
    By tekmassa in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Silicone caulk vs. latex caulk
    By midge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2008, 06:28 PM
  5. Caulk around toilet?
    By Netty in forum Toilet Forum discussions
    Last Post: 07-29-2005, 03:45 PM
