Results 1 to 5 of 5
Thread: Toilet squeeks when flushed
    DIY Junior Member chinar74's Avatar
    Dec 2012
    Maryland
    Default Toilet squeeks when flushed
    We have a new Drake II Toto I installed two weeks ago. Looks great and flushes great, but one minor problem. After about one week, there is a short high-pitched squeak / honk noise when you flush - right as it starts to refill the tank and another at the end of the refill cycle. The water feed valve at the wall is all the way open. Is there an adjustment I can make, or is this a faulty valve? Thanks!
    Mine has always had that little squeak too.
    Quieter than a Fluidmaster though. It's all relative. Some valves are so noisey that you wouldn't have noticed a little squeak; your ears have already been beaten on by high pitched whinning of rushing water through the valve during refill
    Dec 2012
    Maryland
    Thanks - it's not that bad, I was just curious. No one else in the house has noticed the squeak - but they all noticed how well it flushes!
    I could be that your water pressure is on the high side. It wouldn't hurt to pick up a water pressure gauge (about $10) and check it. If you get one with a tattle tale hand, it will register peak pressure if you leave it on say overnight. You can get them with a fitting that will screw onto your hose bib, washing machine, or WH drain, just like a hose; or, get some adapters, and screw it on most anywhere else.
    Apr 2012
    New York, NY
    I had more than a little squeak from the Voreto valve (Type A on this link) that came on one of my Drakes and probably came with your toilet: Toto Valve Servicing Instructions
    I ripped it out and replaced it with a Korky 528 (Type B on the same link). Problem solved, no more squeak. I have 6 of our 7 toilets now with Korky 528 valves, and they shut off without a chirp. They are original equipment on some Toto models, and they are Toto's Universal Replacement Fill Valve (Toto Model TSU99A.X). They come in different configurations; for your Drake II, you could either get the Toto TSU99A.X (made by Korky in Wisconsin) from a plumbing supply place or just get the Korky 528MPK ("MaxPerformance") Fill Valve at Lowe's (or Lowe's.com) for $10.47. They are basically-identical. They take about ten minutes to replace. If you had fun installing the toilet, replacing the fill valve is a piece of cake.
  1. Master bath toilet splashes and bubbles when toilet in neighboring bathroom flushed!
    By redrover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 01:45 PM
  2. Rumbling When Toilet Flushed
    By jpetroz in forum Toilet Forum discussions
    Last Post: 05-12-2008, 08:39 PM
  3. box flushed down toilet
    By FlushyMcFlushagains in forum Toilet Forum discussions
    Last Post: 03-01-2008, 01:09 PM
  4. Basement toilet floods whenever main floor toilet is flushed
    By NGalaxyTimmyo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2007, 06:15 PM
  5. toilet stalls when flushed
    By foghat35 in forum Toilet Forum discussions
    Last Post: 01-01-2007, 05:51 PM
