Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: I want to properly vent a remodeled basement bath
  1. #16
    Jan 2008
    When trying to get up over the edge of the footing, you can cut a notch in the footing and/or come out the the floor at a 45 and then back to vertical in the wall. If you use a 90, you are making a flat vent, which is a no-no.
  2. #17
    DIY Junior Member DeeAnn's Avatar
    Dec 2012
    Detroit, MI
    Ok. Is there any danger to cutting a notch into the footing? I'm thinking no because you're advising it and it would be a very small section of footing.
  3. #18
    Jan 2008
    I would try to avoid it, but others seem to do it without any hesitation.
    An alternative would be to bump the framed wall in a few inches (moving the shower with it) so that there is room to run the pipe up at a 45 past the edge of the footing and still come into the wall.
    edited to add- the flat section of vent in your linked photo is still not going to cut it. Vertical, down to 45 degrees is ok. No less.
  1. Basement bath vent check
    By DVMSteve in forum Remodel Forum & Blog
    Last Post: 12-30-2012, 06:33 PM
  2. basement bath remodel, need some under slab and vent help
    By kentd in forum Plumbing Forum Discussion & Blog
    Last Post: 04-05-2012, 07:32 PM
  3. Is my bathroom vent designed properly??
    By Gnfanatic in forum Plumbing Forum Discussion & Blog
    Last Post: 03-10-2011, 09:21 AM
  4. Hot water to remodeled bathroom
    By krob8000 in forum Tankless Water Heater Forum
    Last Post: 01-19-2010, 02:17 PM
  5. Wet Vent basement bath within 6 ft?
    By sdebord in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2007, 01:20 PM
