Results 1 to 3 of 3
Thread: Need suggestion short hot water heater
Hybrid View
    DIY Junior Member dpw-ct's Avatar
    Feb 2012
    New York
    Default Need suggestion short hot water heater
    I need to replace a 15 year old electric hot water heater in my miami condo. The largest unit that will fit is 22 1/2 inch dia x 32 inches high. Any suggestion on what the biggest and best water heater I can put in. Currently have a 30gal - its ok for the showers but can't fill a large tub (I may just have to live with that - can't really relocate the water heater.
    The size of a water heater is determined by its capacity, since water has a specific volume. Unfortunately, a 30 gallon heater is the only one with that limited diameter. If you can get 24" wide, possibly by taking a door apart to get it into the space, then you have a choice of either a 40 or 50 gallon one, both of them being within your height restriction.
    Feb 2011
    NW Ontario, Canada
    To get more capacity, increase the temperature setting and install a tempering valve to make the output safe. It won't improve recovery time but will provide more hot water.
    If there is adequate supply at the panel, you might consider tankless or hybrid but keep in mind they have limited flow and output depends on how cold the inlet water is.
  1. Short gas water heater, lowboy?
    By Edward Jockers in forum Water Heater Forum, Tanks
    Last Post: 11-15-2012, 05:38 PM
  2. Water Heater Short...
    By pegraves in forum Electrical Forum discussion & Blog
    Last Post: 05-17-2010, 04:52 PM
  3. suggestion to Terry
    By toolaholic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2007, 01:37 PM
  4. shower suggestion
    By scottyt in forum Shower & bathtub Forum & Blog
    Last Post: 07-21-2005, 05:32 PM
  5. Gas Water Heater Suggestion?
    By jasonmcl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-17-2005, 10:30 AM
