Results 1 to 5 of 5
Thread: Ruud Power Vent 2 heating shuts off
    DIY Junior Member jmabram's Avatar
    Dec 2012
    Van Meter, IA
    Default Ruud Power Vent 2 heating shuts off
    I have a Ruud Power Vent 2 hot water heater, model PVRP50-P. It was installed when the house was built, about 7 years ago. It is becoming more and more frequent that it stops heating the water and the water in the tank slowly cools down. If I unplug it and plug it back in it immediately starts back up. My guess would be that there is a problem with the thermostat. Does anybody have any suggestions?
    Plumber jimbo's Avatar
    Does your model have a control panel with LED indicators? If so, what code are you showing? Please provide your model#.
    One issue with power vents is the pressure switch which verifies blower operation, or the blower itself.
    It doesn't take much to cause the sensors to stop operations if there's anything in the flue. A loose connection, some snow, ice, dust, bird's nest, a crack, etc. The hose going to the pressure/vacuum switch may have a crack in it. The switch may be bad.
    Dec 2012
    Van Meter, IA
    No control panel. Just a blinking red light. It is currently working correctly and the light is blinking. When it shuts off the heat and doesn't come back on it is blinking exactly the same way. The thermostat control is made by Robertshaw. Model # looks to be AP12357, but small lettering and hard to read. The hot water heater is a PVRP50-P,
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    RUUD TECHNICAL SUPPORT
    Phone: 1-800-432-8373
    Fax: 334-260-1341
    Available between 7AM - 7PM Central Standard Time (CST)
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Power vent, direct vent or natural draft chimney
    By Islander in forum Boiler Forum
    Last Post: 08-15-2012, 11:51 AM
  2. Replies: 2
    Last Post: 01-27-2010, 07:58 AM
  3. Ruud power vent 2???
    By twilbanks in forum Water Heater Forum, Tanks
    Last Post: 01-08-2010, 09:54 PM
  4. Ruud power vent water heater
    By Peevee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2008, 06:17 PM
  5. Qs about heating system/ eliminating power vent
    By alleycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2007, 06:57 AM
