Results 1 to 4 of 4
Thread: no water for Christmas, please help! well pump suddenly not cycling
    DIY Junior Member moray's Avatar
    Aug 2007
    Washington
    Default no water for Christmas, please help! well pump suddenly not cycling
    Hello,
    We have a Goulds 15S shallow well pump that mysteriously stopped cycling this morning. We have nothing but a trickle coming out of our faucets. The pump has a digital pressure switch (Amtrol), which is reading "31..88..31..blank..31..88..31..blank" etc.. Any idea what I could do to troublshoot this? I tried cycling the power to the pump, but no change.
    It's a newer pump (1-2 yrs), and we've never had any problems with it.
    Many thanks for any ideas! We were expecting 11 for Christmas tomorrow, and don't want to displace our houseguests because we have no water
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    iIf you have a pressure tank on the system I'd try replacing the electronic pressure switch with a regular pressure switch from a big box store. That may get you buy until after Christmas.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Yeah it sounds like a problem with that pressure switch. You can add a regular pressure switch anywhere in line and run the wires to it. You don't have to remove the electronic switch to make the system work.
  1. Well pump cycling on without water use in house
    By hackbrew in forum Plumbing Forum Discussion & Blog
    Last Post: 05-03-2012, 09:55 AM
  2. After brief power failure, I have pulsating water and the well pump is cycling A LOT
    By JamesEarlJones in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2011, 10:01 AM
  3. Christmas and No Water
    By helplessandhopeless in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2010, 11:18 AM
  4. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  5. well pump suddenly stopped working-why?
    By PeteHog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2006, 11:08 AM
