Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
Thread: Dead Culligan Estate 2 - How to remove & what's next?
  1. #46
    Nov 2005
    Central Florida
    Nice; gives me some ideas. Did you do the PEX work yourself?
  2. #47
    DIY Member hiperco's Avatar
    Nov 2011
    Upstate NY
    Glad you like it. Yes I did the pex myself (why, does it look like it, lol)
  3. #48
    Jan 2012
    California
    FYI, the brine draw is not controlled by the BLFC in any way. Most softeners have a directional flow controller in the brine system that only affects refill. The flow control moves out of the way during brine draw. The brine draw is controlled by the injector size and water pressure. All of the Fleck valves operate this way. Even the huge commercial valves with timed or float refill use a simple directional flow control.
  4. #49
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Thanks for the info!
    Edit: guess it was just a coincidence brine fill and brine draw were the same duration on my 7000.
    Lifespeed
  5. #50
    Nov 2005
    Central Florida
    Quote Originally Posted by hiperco View Post
    No, I was planning on doing a major reconfiguration of my system in PEX, but don't have tools, etc., and wondered how dificult & expensive it was. Mine is all 1" though.
  6. #51
    Nov 2011
    Upstate NY
    Pex is great and easy (assuming you can get your crimp tool into every spot you need to) but you do need to invest in the tools. My crimp tool does half and three quarter which covers everything in my house.
  7. #52
    Jan 2012
    California
    When I do PEX, I use Apollo. The tool is reasonably priced and works great. I think it is available at many Home Depots or Lowes. I use the S.S. fasteners, not the plastic for longevity and peace of mind. Their plastic barbed fittings are very high quality too.
    http://apollopex.com/products/3
    http://apollopex.com/products/1
    http://apollopex.com/_products/docs/I-69PTKG1096.pdf
    http://apollopex.com/products/5
  8. #53
    Nov 2005
    Central Florida
    Thanks; any reason(s) to prefer pinch-clamp vs crimp fittings?
  9. #54
    Jan 2012
    California
    The SS are much more expensive, but both work very well. I am simply more comfortable with the SS type.
  1. culligan estate 2 problems... water not soft
    By jstephens in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-21-2012, 04:22 AM
  2. culligan estate 2 water softner not working properly??
    Last Post: 06-10-2012, 09:58 PM
  3. Real Estate Taxes
    By BobL43 in forum Ian's Corner
    Last Post: 09-05-2011, 05:53 PM
  4. Dead Disposal. Can I remove it?
    By llmercll in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2011, 03:14 PM
  5. Pot light wants 1/2 copper real estate
    By Snowmanv2.0 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2006, 12:46 PM
