Results 1 to 15 of 54
Thread: Dead Culligan Estate 2 - How to remove & what's next?
Hybrid View
    DIY Member hiperco's Avatar
    Nov 2011
    Upstate NY
    Default Dead Culligan Estate 2 - How to remove & what's next?
    A few months ago my Culligan Estate 2 failed catastrophically with water spraying out from the control valve. I used the peripheral plumbing already in place to bypass it. Today I noticed its still leaking (slowly), which means my bypass valve(s) probably need repair. In the mean time, I pushed the softener bypass to "bypass" as well.
    Questions:
    1) Can I reuse the existing bypass with a new softener?
    2) If so, how does the control valve disconnect from the bypass valve? I'm guessing they are connected by fittings with o-rings, and all I need to do is remove the screws and u-clip holding them together, then simply pull apart? I assume I can do this without turning off the water (assuming the softener bypass isn't failed in some way)?
    3) What softener should I buy to replace it?
    Name:  IMG_1273 (Medium).jpg
Size:  63.4 KBName:  IMG_1274 (Medium).jpg
Size:  46.0 KBName:  IMG_1275 (Medium).jpg
Size:  62.2 KBName:  IMG_1276 (Medium).jpg
    Pictures attached!
    Dec 2009
    Alaska
    The bypass, the culligan one might need some new o rings if it is leaking out one of the ends after you push the piston left or right.
    There are 2 screws that hold the metal plate to the brass bypass, there are 2 screws that then hold the metal plate to the valve body along with the metal u clip that goes down through the metal plate into the valve body.
    Where was the water leaking from that made you put it into the bypass mode?
    Nov 2011
    Upstate NY
    We have city water with a lot of chlorine, which I would be happy to eliminate as much as possible. Any opinions on:
    1) Waterboss 950?
    2) Kenmore Elite Hybrid?
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    Buy a unit with a Fleck control head. There are online suppliers that sell complete units at excellent prices.
    I don't recommend either of the units you mention.
    Jan 2012
    California
    I agree, the Fleck head unit will serve you for many years, will have parts available, ans is easily maintained. Do not get a unit with the medias mixed inside the same tank. A stacked tank design is fine, or 2 seperate tanks.
    Nov 2011
    Upstate NY
    Are there any units with Fleck heads that remove chlorine? Thanks!
    Jul 2009
    Pennsylvania
    Here is one source of supply--there are other online sellers:
    http://www.ohiopurewater.com/shop/cu...me.php?cat=213
    Nov 2011
    Upstate NY
    I think the brine fill rate is just that. Its how much water goes into the brine tank. Then the brine is drawn out during the brine draw cycle. But hopefully someone that knows for sure will chime in
    Nov 2011
    Upstate NY
    Glad you like it. Yes I did the pex myself (why, does it look like it, lol)
    Nov 2005
    Central Florida
    Quote Originally Posted by hiperco View Post
    No, I was planning on doing a major reconfiguration of my system in PEX, but don't have tools, etc., and wondered how dificult & expensive it was. Mine is all 1" though.
    Nov 2011
    Upstate NY
    Pex is great and easy (assuming you can get your crimp tool into every spot you need to) but you do need to invest in the tools. My crimp tool does half and three quarter which covers everything in my house.
    Jan 2012
    California
    When I do PEX, I use Apollo. The tool is reasonably priced and works great. I think it is available at many Home Depots or Lowes. I use the S.S. fasteners, not the plastic for longevity and peace of mind. Their plastic barbed fittings are very high quality too.
    http://apollopex.com/products/3
    http://apollopex.com/products/1
    http://apollopex.com/_products/docs/I-69PTKG1096.pdf
    http://apollopex.com/products/5
    Nov 2005
    Central Florida
    Thanks; any reason(s) to prefer pinch-clamp vs crimp fittings?
    Jan 2012
    California
    The SS are much more expensive, but both work very well. I am simply more comfortable with the SS type.
  1. culligan estate 2 problems... water not soft
    By jstephens in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-21-2012, 04:22 AM
  2. culligan estate 2 water softner not working properly??
    Last Post: 06-10-2012, 09:58 PM
  3. Real Estate Taxes
    By BobL43 in forum Ian's Corner
    Last Post: 09-05-2011, 05:53 PM
  4. Dead Disposal. Can I remove it?
    By llmercll in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2011, 03:14 PM
  5. Pot light wants 1/2 copper real estate
    By Snowmanv2.0 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2006, 12:46 PM
