Results 1 to 5 of 5
Thread: double sanitary tee vs double combination wye
    DIY Junior Member Jfknz's Avatar
    Dec 2012
    Washington
    Default double sanitary tee vs double combination wye
    Due to a tight squeeze between the floor and ceiling below, we installed a double sanitary tee (accommodating a toilet on one side and a shower on the other). Upon receiving the documentation for the toilet (Toto model MS854114S(G)/MS853113S) we discovered that they recommend against this and instead suggest use of a double combination wye (see page 2 of http://www.totousa.com/Portals/0/Pro..._MS853113S.pdf). Toto recommends wye in back-to-back toilet installations - which is not my situation as tee only serves one toilet and one shower.
    Has anyone had a problem (or success) using a double sanitary tee in a situation like mine?
    Jan 2008
    The problem with doing it with back-to-back toilets is that the water from one toilet can shoot across and effect the opposite one. The shower drain does not flow as such, and should not be an issue.
    The velocity of the flushed water from the toilet is fairly fast...without the 'proper' fitting, it can shoot across to the other fixture (the shower). Probably not enough to come up in the shower, but it is a potential risk. It will also make snaking the line tougher as it may just go across rather than down.
    It's going to mess with the shower. I would install a 3x2 wye lower down the stack for the shower and come up separately for the shower, and then revent at 42" above the floor.
    This is not a good plan what you have done.
    I would not put a shower opposite a toilet. Especially with the new ones that are using a 3" flush valve.
    Depending on HOW you did the shower drain, NEITHER fitting may be "approved" or appropriate. The proper fitting would be a "back to back fixture fitting".
  1. Why Can't A Double Sanitary Tee Be Used Here
    By Hammerlane in forum Plumbing Forum Discussion & Blog
    Last Post: 12-02-2012, 06:22 AM
  2. Double fixture tee or double sanitary tee?
    By nc8861 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-03-2011, 11:33 AM
  3. double sanitary tee in Canada
    By segal46 in forum Canadian Plumbing Code Questions
    Last Post: 06-26-2010, 08:37 PM
  4. double sanitary tee in Canada
    By segal46 in forum Plumbing Forum Discussion & Blog
  5. Double Sanitary Tee or Double Wye?
    By MG in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2007, 11:45 AM
