Results 1 to 4 of 4
Thread: Problems with water softener, Kenmore
    DIY Junior Member Kram's Avatar
    Dec 2012
    Default Problems with water softener, Kenmore
    Have a Kenmore water softener that is over 10 years old. We are having the following problems. 1. Water is salty when faucets are first used in the morning. 2. Unit is using a lot more salt than it did previously. 3. Brine well is over half-full of water (water is above top of salt). Not sure if these problems are related, but any help/suggestions would be appreciated.
    Feb 2011
    NW Ontario, Canada
    Have you watched the regen cycle to see if all the brine is drawn out before it refills? If less is drawn than what refills, the level will ratchet up. That would suggest a problem with the draw.
    Dec 2009
    Alaska
    And with the age of the unit and depending on the quality of the water , it could be time for a rebuild of the valve or a very good cleaning of the valve.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    With the unit in a service position, disconnect the brine line from the valve and see if water is dripping out. If it is, you will need a rotor seal kit and possible a new rotor.
  1. Kenmore water softener
    By dt196 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-21-2014, 09:10 AM
  2. Kenmore Softener Problems
    By btb079 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-03-2011, 07:07 AM
  3. Kenmore water softener
    By dt196 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-26-2009, 04:29 AM
  4. Kenmore Water Softener help?
    By a12548 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2008, 01:10 PM
  5. Kenmore Water Softener
    By DarylF08 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 09:21 AM
