Results 1 to 8 of 8
Thread: Another toilet flange question
    DIY Junior Member miltf's Avatar
    Dec 2012
    Alameda, CA
    Default Another toilet flange question
    Hi,
    I have removed our old 1930's toilet and discovered that the flooring and the 4" cast iron pipe are connected by a lead sheet collar. I am thinking to install an Oatey twist and set flange and bolt it to the flooring. Is this right? How can I ensure a good seal to the pipe which does not have a smooth surface? What is best: cast iron flange, abs flange, ss covered flange?
    Any other ideas? I am reluctant to remove the lead and start over.
    Thanks,
    Milt
    None of those are approved or reliable in this situation. If the lead is intact, a plumber can lead on a new brass or bronze flange. If it's not, then it gets much more involved - the lead needs to be removed. Then, you have the choice of using whatever material you wish, pvc, abs, cast iron, or even copper to rebuild the pipe and install a new flange. There are no friction or expansion flanges designed to work inside a lead sleeve.
    Aug 2009
    South*East
    If the lead is in good shape there is no need to solder a flange onto it. Just straighten the folded section of lead and slide the new flange over it. Then fold the lead back over the flange. Use the shorter flange in the link.
    http://www.siouxchief.com/Drainage/R...nge-Ring.7H0Q5
    John
    Dec 2012
    Alameda, CA
    Its not easily seen, but the lead only goes down about an inch to where the iron pipe starts. I was thinking the flange extensions would fit against the iron.
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    If that's lead which is soft, where is/were the closet bolts that hold the toilet down? Or was something else used back then?
    Bill
    Just a DIY'r
    Aug 2009
    South*East
    Many didn't use flanges they used closet screws that fastened the toilet to the floor. Not a good idea.
    John
    SOmetimes, they'd lead a brass flange to the lead after it was wrapped over it (the lead, that is).
    Aug 2009
    South*East
    The lead was soldered to the brass flange.
    John
  1. Another toilet flange question
    By greyhound1 in forum Toilet Forum discussions
    Last Post: 10-20-2012, 05:13 PM
  2. Yet another toilet flange question...
    By jim24 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2010, 09:13 PM
  3. Question re:toilet flange
    By fatdaddy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2008, 06:32 AM
  4. Toilet Flange question
    By prashster in forum Toilet Forum discussions
    Last Post: 05-04-2006, 08:51 PM
  5. toilet flange question
    By tomcobb in forum Toilet Forum discussions
    Last Post: 12-22-2004, 10:18 PM
