Results 1 to 6 of 6
Thread: Cleanout under lavatory, how to?
    DIY Junior Member waltsyd's Avatar
    Nov 2012
    Three Rivers, CA
    Default Cleanout under lavatory, how to?
    I've never seen a cleanout under a lavatory sink but now I have to put one in on a bathroom addition. It's a 2" waste and vent (needed to boost total area of VTR) that has a big change of direction before tying into the main drain.
    So I gather the cleanout t sits just above the trap san t. It seems like it's gonna be pretty cramped in there if anyone ever needs to use that cleanout. I'm not even sure it will have the requisite 12" clearance. Do I aim it a bit to the side? Should the waste san t be set lower down? Any other tips?
    Jan 2008
    A cleanout can be installed above or below the sani-tee. If you are going to put in a pedestal sink, you might want to skip it. It's not usually that big of a deal to remove the tubular trap and trap arm and just snake through the sani-tee.
    Nov 2012
    Three Rivers, CA
    It will be a standard 18 inch sink in an 18 inch vanity with doors. I like the idea of being able to put water into the drain while rodding by having a separate cleanout t, but if it's allowed, I think I'll just use the trap san t as the cleanout. Anyone had an inspector dislike that?
    quote; If you are going to put in a pedestal sink, you might want to skip it. It's not usually that big of a deal to remove the tubular trap and trap arm and just snake through the sani-tee.
    That sounds like someone who has NEVER had to take a pedestal trap apart. Nomally, the space is so compact that you do NOT toubh the trap unless it is absolutely necessary. In this area, the inspectors do NOT consider a "trap" to be an appropriate cleanout option.
    Nov 2012
    Three Rivers, CA
    So what do you do to put a cleanout in there since your area doesn't allow the trap as a cleanout? Above the p-trap, below (sounds odd to me), to the side, what? It's a vanity, not a pedestal.
    Jan 2008
    Put it where it will be the easiest to open up and run a snake down.
  1. Lavatory Drain
    By Book3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2012, 07:20 AM
  2. New Lavatory P-Trap
    By pensfan84 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2009, 04:33 PM
  3. Attaching a cleanout to a cleanout
    By vanhoudn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-12-2009, 12:15 PM
  4. Leaky Lavatory
    By Erniek in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2009, 10:28 AM
  5. Brass Cleanout Plug in ABS Cleanout Tee?
    By Shinshi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2009, 05:03 AM
