Results 1 to 5 of 5
Thread: DWV Rev 1 with reccomendations
Hybrid View
    DIY Junior Member accidentalplumber's Avatar
    Dec 2012
    Issaquah,Wa
    Default DWV Rev 1 with reccomendations
    Hello All
    I have made some clarifications and changes that were made by Terry L. Do this look like what the inspector will be looking for.
    John
    Sep 2009
    Seattle. WA
    You will notice that Mr. Polk does not mention using the combo fitting to connect a horiz. drain to a vert. drain.
    A sanitary tee would be more appropriate, and in the case of the vertical vent taking off from the tee, a santee
    would be required.
    Dec 2012
    Issaquah,Wa
    Attachment 18322 Thank you for the response kreemoweet. Here is another revision.
    Nov 2010
    Maine
    That tee for the future is not acceptable. Also, the washer and tub can't both occupy the same 2" stack
    In Issaquah, you will need 2" on the tub until the vent, then 1.5" for the trap and trap arm.
    It would be a good idea to separate the tub from the washer stack for suds control. You really don't want washer suds coming up in the bath tub.
    The toilet looks fine now.
    The kitchen will need a 2" cleanout accessible in the cabinet below the sink.
  1. *Submersible Pump* Need Reccomendations
    By mexicodiesel in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-06-2009, 04:04 AM
