Results 1 to 3 of 3
Thread: newb question about new sprinkler system
    DIY Junior Member diney01's Avatar
    Mar 2013
    framingham, massachussets
    Default newb question about new sprinkler system
    Hi everyone!
    we have a lake house, so the lake water will be my source...
    yard size is 150ft from the house to lake and 100ft sides very level yard..
    could you guys please help with exacly what i will need for this project.?
    if i can get a list of everything i will need is much easy for me go at store and buy em...by the way i want to be underground irrigation, i dont have a problem i digging
    sorry if my question doesnt make any sense..i hope u understand i need help i want install this next week i have all week off..
    thank you all
    This is bigger than a one week DIY project! First, you must start with a good design plan. All the big companies, Toro, Rainbird, Orbit, etc will provide something like that, usually free. They may even provide a parts list of all the heads, etc. Just assume you will need to buy several hundred feet of pipe....in most likely a mix of 1", 3/4", and 1/2". This is where the design comes in, because if you undersize the piping in any part of the system, it will never work right.
    You need to decide what kind of pump you need....and comes the design again.....you have to have the system designed into zones so the flow rate on any zone will not exceed pump capacity.
    Sprinklers are a good DIY item, but it is more complicated than you may think.
    Yakima WA
    Ditto Jimbo's comments. Make an accurate scale drawing of your property. Elevation change would be important as well, at least a close guess. Show your build(s) trees, shrubs, etc.. The designs are usually provided free, but if not, a reasonable charge would be money well spent. Usually, the only requirement for the free design is that you buy all of the materials from them. When I did mine years ago, I was surprised to learn their prices were no more than the Big Boxes and often even less. Plus, if you have a problem during the install, they can give you accurate answers. An irrigation system is too big of a job to just go out and glue pipe together and hope it works.
  1. DIY Sprinkler System
    By kimbhoot in forum Irrigation / Sprinkler Forum
    Last Post: 04-24-2012, 09:07 PM
  2. Sprinkler System Drain Question
    By bchstrad43 in forum Irrigation / Sprinkler Forum
    Last Post: 09-09-2009, 07:10 AM
  3. New to sprinkler system
    By swift_3 in forum Irrigation / Sprinkler Forum
    Last Post: 05-27-2009, 10:14 AM
  4. Newb question...washer outlet box drains
    By dabiz7 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-29-2008, 06:33 AM
  5. Need Help With Sprinkler System
    By SUE2 in forum Irrigation / Sprinkler Forum
    Last Post: 08-25-2006, 11:58 AM
